Author Topic: Sticky clutch pedal  (Read 2879 times)
Offline mickysuperstar
Sticky clutch pedal
« on: 04 April 2010, 20:31 »
Howdo!!
Got a recurring issue with my 1992 mk2 8v gti, which had just got worse this weekend...
Basically, the pedal doesn't return back to the correct point after it has been pressed... It kinda sticks half way!
The clutch doesn't slip or seem to be open when the pedal is at that point, but its annoying!
It used to happen every now and again, but now happens 9 times out of 10!
Hope the description makes sense??
Any help would be wicked!!
Cheers!!
1992 MK2 GTI 8V FOR SALE!
Offline Neo Badness
  • Feet are for pedals
Re: Sticky clutch pedal
« Reply #1 on: 04 April 2010, 20:41 »
Grease the visible clutch cable that attaches to the gearbox arm. Cable is sticking inside the sleeve. Just to be doubly sure wd40 the pivot point inside the car on the top of the clutch pedal.  :wink:
Had a similar problem after changing my clutch cable, albeit not as severe, just hadn't put enough grease on it.
NB
« Reply #2 on: 04 April 2010, 20:49 »
Ahhh nice one - thanks Kate.
I've already soaked the pivot point in WD40, so will grease up the clutch cable tomorrow.... Fingers crossed!
Thanks again dude, I'll let ya know how I get on!
Offline Neo Badness
« Reply #3 on: 04 April 2010, 21:27 »
SSSshhhhhh, only on a Wednesday night :laugh:
« Reply #4 on: 06 April 2010, 09:08 »
I'd replace the cable, sounds liek its starting to fray inside. also if clutch pedal is higher than the brake pedal the pedal stop has fallen off
