cool , can i pay via card on the day ? also whats the cost for stage 1 on my gti aum ?
i have in the past few months done - k+n panel filter , forge 007 valve , coolant temp sensor .
last week (late night) i have fitted new - ngk platinum plugs , cambelt + tensioners , waterpump , fanbelt , thermostat , antifreeze , n75 valve (all dealer parts) and done a throttle clean + reset . so hopefully all the above will make it a bit easier for you to map without any probs on the day or near future !!
only code i have got is the dreaded 17705 which i cant find ! it may well be due the a leaking suction jet pump under the inlet (three way valve?) as it seems a bit oily ! but i think you use smoke now to find leaks ? cheers
ps im a mechanic at a garage in brighton so i guess you can do the job there ?
