Author Topic: Lumpy 16v  (Read 3050 times)
Offline Neo Badness
  • Feet are for pedals
Lumpy 16v
« on: 03 April 2010, 17:02 »
Have followed the info regarding 16v KR running a bit flat, seems to have come on recently.
 Slightly lumpy idle, like it's cammed, but it's not. Have checked/ cleaned out ISV. 3rd gear light throttle seems to be holding back or missing. Just all round bit flat for want of better word, doesn't have any urgency. Suspecting a vac leak as it's coming on slowly getting worse.
Plugs are new, dizzy/arm new, new cam belt and waterpump.
I've got to replace the fuel lines/ fuel distributor on my KR 16v (they look like they've been at the bottom of the sea!)
Got replacement lines and fuel distributor c/w lower inlet and injectors, but they're 2nd hand so thinking it'd be simpler to replace with new injectors & seals etc.
 Anyone know part no's please?
Also how'd you get the injectors out without wrecking them.
Another question is anyone recommend where to get some decent plug leads for KR?
Also where to get new Vac lines/hoses for the KR too as I think I have a slight air leak causing it to run flat/ poor throttle response.
Cheers in advance
Offline Neo Badness
Re: Lumpy 16v
« Reply #1 on: 03 April 2010, 20:20 »
Anyone?
Why are 16v plug leads so exspensive??
Offline walchy01
Re: Lumpy 16v
« Reply #2 on: 03 April 2010, 20:26 »
Just what I want to know, 80 quid at the dealers...
Offline Reasty
  • Alpine white valver.
Re: Lumpy 16v
« Reply #3 on: 03 April 2010, 20:34 »
It's to do with the amount of shielding on them,I've just bought a set of 8mm Magnecores for my 16v and they where £130 quid!
Offline Reasty
Re: Lumpy 16v
« Reply #4 on: 03 April 2010, 20:39 »
Has the lack of power come on since you had the cambelt done? if so have the timing checked,you'd be suprised how much of a difference a freshly tuned and timed up 16v feels to drive.
Offline Neo Badness
Re: Lumpy 16v
« Reply #5 on: 03 April 2010, 20:42 »
Yeah they look cool was looking at some Magnecor KV85's but yeah 130.00 a throw was like, are they frikin magical or something?
Scurry out to the car and fit themselves? :rolleyes:
There's a + in the 8v argument  :grin:
Yeah it was timed when the belt was done but do they out of time? Was running strongly then seems to have papped out a bit of late. Thought I'd got a bad batch of petrol but just won't rev cleanly. Will call garage on Monday see what they have to say about it...
Offline Reasty
Re: Lumpy 16v
« Reply #6 on: 03 April 2010, 20:59 »
I'll let you know about the leads when they arrive!  :smiley:
In my experience when ever my valver has started to feel abit flat I whip her over to the guys at the Phirm and they tinker about un the bonnet for half hour and she is like new again,I do think the 16v kr's need a tune every now and then to keep them running sweet,well mine does anyway!  :grin:
Offline Neo Badness
Re: Lumpy 16v
« Reply #7 on: 03 April 2010, 21:11 »
Yeah, I have guys @ Target Motors in Dundee, they seem to know their stuff. I have an ABF lurking in the garage and if I hadn't just spent a small fortune getting the KR sorted it'd be getting punted in favour of more cc's :grin:
Thinking of changing my GTi badge for an LS one. LS standing for Little Sh!t. My mk2 Driver was indestructible where as this one needs this and that and seems to manage about 200 odd miles before it has something needing done :rolleyes:
Re: Lumpy 16v
« Reply #8 on: 04 April 2010, 17:16 »
beru leads from gsf or avs will do you, around £40.
as for your symptoms, try swapping the wires round on the 3 sensors on the side of the head
Offline Neo Badness
Re: Lumpy 16v
« Reply #9 on: 04 April 2010, 19:35 »
iirc it was Beru leads that I got from the motofactor for 40.00, made symptons worse (like I'd mucked up firing order, but hadn't) Noticed the Beru leads didn't have the ceramic shielding in them like my old ones. Was offered OEM replacement leads for 80.00 but was still peed off about the crappy leads so left it for time being.
swapping wires round on 3 sensors on the side of the head? They're the temp sensors aren't they?
 Will have a look during the week when I get back. Will see if it makes a difference. Have list of to do's and dones...
1.Fuel pressure is low. Check both pumps are operating well.
2. Timing/CO2 is out?
3. Compression is low for some reason? (valve seals etc.)
4. Temp sensors 3 sensors on the side of the head
5. ECU/TCI/Coil issue
6. Leads are knackered(?)
7.  rotor arm and dizzy cap.
8. Worn/clogged injectors or injector seals?
9.  spark plugs
