Author Topic: Difference in these intercoolers?  (Read 2423 times)
Offline Rhyso
Re: Difference in these intercoolers?
« Reply #1 on: 03 April 2010, 15:26 »
the 130 has bigger inlet and outlets thus the pipe diameter will be different between the two kits hence the price difference
Offline EuanGtTdi
« Reply #2 on: 03 April 2010, 16:17 »
thats what i thought but on both of them the inlets are the same 2.5" or 64 mm  :huh:
Offline Rhyso
« Reply #3 on: 03 April 2010, 16:20 »
On the intercooler maybe but the outlet from the turbo's are different between the 90, 110 and 130 so I'd assume the pipework is different somewhere along the line to accommodate this  :undecided:
Offline EuanGtTdi
« Reply #4 on: 03 April 2010, 16:22 »
aww right okay mate mines is the 115 so do you know what size of pipework ive got the same as?  :smiley:
Cheers Rhyso
Offline Rhyso
« Reply #5 on: 03 April 2010, 16:24 »
Cheers Rhyso
Urm pass - I've got a feeling they are unique between every model  :undecided:
I can tell you that's its NOT the same as the 130 and 150 so that should help narrow it down  :tongue:
Offline EuanGtTdi
« Reply #6 on: 03 April 2010, 16:26 »
okay doky cheers mate
Offline EuanGtTdi
« Reply #7 on: 03 April 2010, 16:29 »
also ryhs whats the sensor that goes onto the intercooler?
Offline Rhyso
« Reply #8 on: 03 April 2010, 16:30 »
Had a quick look on ETKA for you and the 110 and 100 has the same part numbers for your engine code
MAP sensor :afro:
Offline EuanGtTdi
« Reply #9 on: 03 April 2010, 16:31 »
aww cheers mate so take it will probably fit then do u mean 90 not 100? :grin: since have same numbers?
what does a map sensor do?
