Author Topic: 1st gear problems!!  (Read 1734 times)
Offline justin
1st gear problems!!
« on: 18 November 2004, 17:34 »
Hello again!!
I've got a 91 mk1 cabby gti and when i select the reverse gear and reverse round a corner when i try to select 1st gear to set off it goes into 3rd. When i try to select first i just will not go in so i end up setting off in 2nd. After a very short while (like pulling up a traffic lights) i can select 1st gear with no probs! Any ideas?
Dinky
Re: 1st gear problems!!
« Reply #1 on: 18 November 2004, 18:13 »
Mine does exactly the same from time to time,tis ok for to go into first wen its moving but hav had trouble wen stopped n,like u say,wen havin reversed first,then into gear.I think a few people hav noticed this n sumone has mentioned that it may b sum sort o fail safe ????
or.. :P
http://www.golfgtiforum.co.uk/index.php?topic=6308.0
Dinx ?:-*
« Last Edit: 18 November 2004, 18:33 by Dinx »
kniterider
« Reply #2 on: 18 November 2004, 18:17 »
sounds like the same prob i had on my scirocco (same linkage set up etc), lift up the leather/pvc gear stick surround, look down and youll see a metal plate around the base of the gearstick, there should be 2 10mm headed bolts one at the front and one at the back, loosen these off, move the plate and gear stick (will move with plate) over to the left as far as you can then tighten it up, then try your gears and all should be returned ok!
Gaz ;D
Offline justin
« Reply #3 on: 18 November 2004, 20:40 »
Cheers,
i'll give it a go this weekend, i'll let you know how i get on!! Its typical tho, with christmas around stuff starts to go wrong with me car!!
Offline Agreeable Slick
  • Unit
« Reply #4 on: 18 November 2004, 22:18 »
guys there are usually 2 balls at either end of the linkage.
These 2 bushes usually tend to "disappear" after a certain amount of time, lift up the gear cover and you should see a white one around the bottom of the gear selector rod, and then look in the engine bay where you can see the rods again, there should be another golf ball sized one on the other end of the same rod, if either one is missing it would explain the difficulty of getting it into first.
I had the same problem on my mk2.
Offline justin
« Reply #5 on: 06 December 2004, 17:53 »
Cheers Knightrider that solved the prob!!
Offline hairyarse
« Reply #6 on: 08 December 2004, 10:49 »
I may be covering the same ground but could it be whole linkage kit needs doing/selector rods etc.
If you look in Haynes manual should give you all the tips on setting up/adjusting to sort any sort of problem like this :wink:
