Golf mk2
Resetting clocks
Topic: Resetting clocks (Read 1123 times)
TIM20
GTI forum regular
Resetting clocks
18 November 2004, 16:43 »
I have had some problems with my clocks aso have reset them by leaving out fuse 21 over night
I now don't have any mfa readings and my rev counter is dead
How do you get it all working again after resetting??
Cheers Tim
Rain
Guest
Re: Resetting clocks
18 November 2004, 19:40 »
why was you resetting it by taking out the fuse?
Veedubgt18v
Guest
18 November 2004, 22:35 »
taking the fuse oiut over night shouldnt have done that! put the fuse in, start the engine and take the fuse out then put it back in and it should work, that is exactly what mine did and i did this and it worked done it loads of times since to!
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
19 November 2004, 12:27 »
If that fails try leaving the negative lead off the battery overnight instead. I've never had to do it that way though!
What year is your car and did you check the fuse number with the back of the fusebox cover?
Golf mk2
Resetting clocks
