Author Topic: big disk brake pads  (Read 830 times)
Offline georgenewman1
big disk brake pads
« on: 02 April 2010, 19:45 »
hi guys ive put the 280 conversion on my golf today using callipers and carriers and found the standard pads dont fit properly theyr the rite pattern but the tabs seem a little short on the sides, went to the motorfactors i use and we went through both mintex books and couldnt find any, does anyone have any ideas of the part numbers for the proper pads, cheers G
Offline cняis
Re: big disk brake pads
« Reply #1 on: 03 April 2010, 12:27 »
pads to suit either 280mm g60 or ibiza 2.0 16v (around 97ish) setup  :smiley:
Offline sprout99
« Reply #2 on: 03 April 2010, 18:59 »
i used 280 carriers and std callipers. HAd to gring slide pins down and use std pads
for the 256mm brakes (16mm thick)
very tight to fit but all ok now
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
