Author Topic: door and window seals  (Read 1128 times)
Offline bosco
« on: 02 April 2010, 16:59 »
my mk2 has been letting water and im nearly sure its the window and door rubbers. does anyone no where i could get them. i live in ireland but it doesnt matter where i get them. thanks
1990 mk2 1.6 daily
1990 20v turbo project learning as I go
Offline Thom89
  • Looking for an "Icebreaker"
Re: door and window seals
« Reply #1 on: 03 April 2010, 02:02 »
Its most likely that your door membrane is letting the water in, remove the door card, and check that its in perfect condition..
door and window seals are never a perfect answer to water ingress, thats why doors have drain holes, and membranes!
Sometimes its easier to replace the membrane with good quality polythene sheeting, and spray adhesive, taking note to cover all the holes on the inner door frame, as per the original, a good fit is the key here.
Thom
