Author Topic: Midline Display - auto lock doors?  (Read 3008 times)
Offline p3eps
« on: 02 April 2010, 15:16 »
My mate has recently bought a MK5 R32... and has a midline display.
I got a VagCom the other day, and he's asked me if I can set his doors to autolock / unlock.
Do you NEED the VagCom to do this, or can you still do it with the midline?
If I do need to VagCom it, how do I do it?  I'm only had the VagCom for a week and haven't really had a chance to play with it!
Cheers...
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline ub7rm
Re: Midline Display - auto lock doors?
« Reply #1 on: 02 April 2010, 20:02 »
If he's got the display showing the doors open its the highline display and should be able to change the settings via that.  :smiley:
2020 BMW 128ti
2017 Golf GTD Estate
Offline p3eps
« Reply #2 on: 02 April 2010, 20:36 »
I'm well aware that the highline display lets you change the settings, but his car has the midline display - where half of it is missing.
I want to know if you can still change the settings on the midline - or whether I need to VagCom it?
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 02 April 2010, 21:18 »
I don't think it's possible, although to be honest i never really tried on mine because it's so simple with vcds. Just use the long coding helper in the CCM and it's as easy as ticking boxes.
Offline p3eps
« Reply #4 on: 02 April 2010, 21:29 »
Thanks... I didn't think you could do it with Midline, but I wanted to check first.
CCM - Central Control Module?
If it appears in the Long Coding Helper then I should manage to figure it out.
I've also got an R32 aluminum foot rest to fit for him whilst I'm there!
Offline stealthwolf
« Reply #5 on: 03 April 2010, 00:01 »
I have midline and you can't do anything with it. It has a trip computer and that's it. You need highline or vagcom to do anything. If you have midline, you need vagcom.
Offline p3eps
« Reply #6 on: 03 April 2010, 18:37 »
It worked a treat with the Vagcom, and discovered a fault with his Alarm Horn.
The footrest from Gulfstream11 fitted great, and went down very well.
Thanks for the help  :nerd:
