Author Topic: Indicator problem!  (Read 1048 times)
Offline jamie_pyrite
Indicator problem!
« on: 02 April 2010, 01:21 »
So I have a problem with my '91 mk2 valver.
The indicators don't work properly! If the battery is connected, the left hand side indicators (front, side, rear) stay on. If I change the indicators to turning right, the indicators flash double time (as my front right indicator is out). If I change the indicators to left, nothing happens. Nothing happens when pressing the hazards on either.
I replaced the number 21 relay and it worked for a day, now no longer works! I've checked it's plugged in properly too.
Any ideas? Is it possible that some dodgy wiring is blowing my no. 21 relay?!
Very stressed, I need to get the car MOT'd in the next 2 weeks and can't in this state :(
Thanks
Offline shaolindan
Re: Indicator problem!
« Reply #1 on: 02 April 2010, 15:39 »
At a guess I would say you need to replace the stalk.
Golf GTi 8v mk2 1990
Coilovers, BBS RA, K&N Induction Kit...
« Reply #2 on: 02 April 2010, 17:44 »
So you'd suggest trying another set of stalks on the car then?
Would there be anything else I should check?
« Reply #3 on: 04 April 2010, 02:19 »
Right so this has turned out to be a problem with the alarm! Through research online, I've diagnosed it as a sticking relay which controls the indicators inside the alarm control unit. It's basically stuck on.. I've read a method of fixing this by an engineer that works for Sigma so going to do that next week :)
