Author Topic: Suspension problem..help please!  (Read 10552 times)
Offline cornishrex
« on: 01 April 2010, 20:08 »
Hi all,
Think I have a suspension problem, the gap between front and rear wheel arches seem to be quite different with the rear about an inch or so lower than normal and the front about 2 or so higher, at least I'm guessing, Ive had a couple of mk3s before but this is the first GTI and looking at other GTI's the back is definately lower...thought it might be rear shocks/springs but any thoughts?
cheers
Offline Deano2711
  • 1992 VR6
Re: Suspension problem..help please!
« Reply #1 on: 01 April 2010, 20:36 »
Could have been lowered by a previous owner. Mine was lowered 40mm on rear when I bought it but standard on the front.
Offline Dubpower
« Reply #2 on: 01 April 2010, 20:40 »
did you do the bounce test on them????????
if not you open the bonnet (make it easier to see the top mounts and see if there gone) and press down 3 times and see if its very bounce or just stops.if it stops then they should be ok
same for the rear
then lift up the shock cover and you should see a shinny part on it.rub you finger around it and see if you have oil on your fingers after you rub them together.
after all of that you will know if there gone or not  :smiley:
you probably know this already lad but it is always good to do every so often  :wink:
also are these stander-ed shocks or after market versions?????
Offline cornishrex
« Reply #3 on: 01 April 2010, 20:42 »
true  :wink:
was it way up at the front when you got it? this is like 5 inches between arch and tyre at the front
« Reply #4 on: 01 April 2010, 20:45 »
This is standard GTI 8v height
Offline cornishrex
« Reply #5 on: 01 April 2010, 20:49 »
cheers dub,
yep, theyre bog standard shocks, done the bounce test, no probs, no oil leaks either,  the front top mounts were replaced for the mot about a month ago, but the car has been high for a lot longer than that
nice pics...cheers for the reference, mine is about 2-3 inches higher than that at the front and probably 2 lower at the rear
have also made sure the engines not out and in the boot too lol
ps...pics at Cheddar Gorge?  :wink:
« Reply #6 on: 01 April 2010, 20:59 »
cheers dub,
Yep Cheddar Gorge, refernce sitting high, could be the wrong springs maybe.
« Last Edit: 01 April 2010, 21:01 by Wayne »
Offline Dubpower
« Reply #7 on: 01 April 2010, 21:03 »
no probs lad.
I think that aswell what was said above  :wink:
Offline cornishrex
« Reply #8 on: 01 April 2010, 21:04 »
guess it could be..Ive a set of old rear shocks in the garage, Think I'll fit them tomorrow and see if that makes a difference, so long as the rains stopped   :sad:
is there anyway of identifying the springs? they look standard..black with white and green dots?
« Reply #9 on: 01 April 2010, 21:07 »
I am only quessing but diesel or VR springs on the front would raise it.
