Author Topic: temp sensor + service light  (Read 827 times)
Offline aaran
« on: 01 April 2010, 12:30 »
quickie i got my temp sensor from work yesterday and it looks just to be a psuh in plug for my agu is it jsut a case of pulling the old one out and pushing the new one in? would have thought it would have been a threaded body?
also the service light is on the dash (says service/inspection) already done the oil+fuel filter and plugs etc etc 500 mile ago, where in vagcom do i turn the message off?
and lastly when the screenwash bottle is low does the car normally beep loudly at you when you start it lol? (most annoying)
Offline Waffs1984
  • Spacers are for chumps...
Re: temp sensor + service light
« Reply #1 on: 01 April 2010, 12:39 »
Temp sender - yes, you remove a c-clip that holds the old sensor in (don't lose the o-ring!) and simply push the old one in the hole and repace the c-clip.  :smiley:
Service light/message reset (need to do this on mine actually!);
1. Ignition off - press and hold reset mileage
2. Ignition on - release reset mileage
3. Turn clock adjuster to the right (as you would if adjusting minutes). Should now be clear.
Screenwash bottle beep - erm... top up your screenwash maybe?  :huh:
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
Offline richw911
