Author Topic: Clutch cable problems  (Read 2214 times)
Offline mikehorne
« on: 31 March 2010, 18:58 »
Help!!
After the clutch cable giving up(the plastic end at the pedal)i bought a replacement from a local motor factors,
I checked the length on the original and the cable iternal was about 15mm longer but i put this down to the old one stretching?
I then fitted it anyway but now the car selects all gears but won't move(no biting point) now i'm thinking is this the correct cable for the car or not? :cry:
Offline mikehorne
Re: Clutch cable problems
« Reply #1 on: 31 March 2010, 19:01 »
OOps it's a mk2 16v 92 on a k plate :embarassed:
Offline cняis
« Reply #2 on: 31 March 2010, 19:04 »
does the 16v have an auto-adjusting cable or manual adjust? if its manual adjust it needs.... errr adjusting!  :smiley:
couldnt they cross the numbers off the old cable?
Offline mikehorne
« Reply #3 on: 31 March 2010, 19:17 »
It's one of those daft self adjusting ones and up until now i had no reason to think it's not the correct one for the car.
Offline cняis
« Reply #4 on: 31 March 2010, 19:32 »
take it back to the motor factors along with the orginal (or at least the part number on it) and get them to sort another one!!
Offline dan_apps
  • too low for british roads!
« Reply #5 on: 31 March 2010, 20:26 »
i went for the manual adjusting one for this reason. bloody nightmare to mess about with the autos are.
Offline Neo Badness
  • Feet are for pedals
« Reply #6 on: 31 March 2010, 20:46 »
Auto adjusting cables take a fair few pumps of the pedal to adjust. As far as I gather they changed to auto adjusting 16v 89(ish). Had changed mine as old one was slipping took it out for a spin, no massive improvement :evil: few miles later it was working properly :smiley:
Provided it was fitted correctly first time round and you just did reversal of removal when fitting shouldn't be an issue.
Offline mikehorne
« Reply #7 on: 31 March 2010, 20:56 »
I'll try and give it plenty pumpin in the morning.. :grin:if that doesn't work back to the factors it'll go :laugh:
Offline Neo Badness
« Reply #8 on: 31 March 2010, 21:07 »
Sounds like a plan. Just make sure you don't go blind :wink:
Offline mikehorne
« Reply #9 on: 31 March 2010, 21:20 »
Ha Ha i won't be pumpin at the factors like!! :laugh:
