Author Topic: Turbo Cleaning Kit  (Read 17481 times)
Offline asif
Re: Turbo Cleaning Kit
« Reply #20 on: 31 March 2010, 16:23 »
I just called R-tech they said #95 to get your turbo cleaned that's with them providing the kit and the labour to do it, does that sound right or a tad dear?
How long does it take to clean i.e how much labour time would it be?
MK7 GT Bluemotion Tech TDi 150
Offline Rhyso
« Reply #21 on: 31 March 2010, 16:29 »
Re-read my previous post  :rolleyes:
And try finding someone who will do it cheaper............
« Last Edit: 31 March 2010, 16:32 by Rhyso »
Offline dubber36
« Reply #22 on: 31 March 2010, 16:32 »
Before you spend your money on this, you should try Millers Eco Max, (or whatever it is called these days)
It really does work. It has cured several cars that I know of that have been suffering from going into limp mode due to overboost caused by sticky vanes. Give it double dose to a tank of diesel, and give it some good runs with lots of on and off boost. Then add a dose every time you fill up and you'll shouldn't have the problem again.
It costs around £1 per tank of fuel, but you'll save more than that in increased fuel economy.
Offline MarkyMark1983
« Reply #23 on: 31 March 2010, 16:38 »
Millers Oils Diesel Power Ecomax.
High specification diesel fuel treatment for enhanced combustion efficiency and engine cleanliness, now with improved detergency. Millers Oils Diesel Power Ecomax For use in all diesel vehicles including modern Euro IV compliant engines.By addition to fuel in the ratio 1 part to 1000 parts [1 ml/L].  May also be used at double strength for additional performance.
User Benefits
Diesel Power ECOMAX is a modern state of the art fuel treatment that is suitable for all diesel engines, especially Euro IV emission-compliant vehicles, which also provides a tangible improvement to vehicle performance.
Enhanced detergency package for quicker clean up and prolonged injector cleanliness.
Increases cetane rating of diesel by 4 numbers.
Improved throttle and engine response at lower revs designed to offer the best of both power and economy.
Protection of fuel system components against wear, with specially added lubricity enhancers.
Engine smoothness, noise reduction and fuel savings confirmed by users.
Improved combustion and engine cleanliness drastically reduces emissions of hydrocarbons (HC) and carbon dioxide.
Provides fuel system corrosion control.
Prevents fuel from ageing.
Millers Oil Diesel Power Ecomax is also known as;
Millers Diesel Power Ecomax
Millers Diesel Power Eco max
Millers diesel fuel treatment
Millers diesel additive
« Reply #24 on: 31 March 2010, 16:41 »
that millers stuff costs 11-12quid a time. With that turbo  leaning kit it does specific the turbo and not everything around it. Will give it a try like tho got some of that redex gold diesel treatment to tryout see if it works
Offline Rhyso
« Reply #25 on: 31 March 2010, 16:45 »
It comes with a bottle of injector cleaner too which you stick direct into the fuel filter
Offline asif
« Reply #26 on: 31 March 2010, 16:48 »
Tried that Millers stuff no real difference for me but I suppose it must be doing something good somewhere and can't be doing any bad.
Nothing wrong with a good old clean.
Well judging by what you've said Rhyso I think i'll shop around and see if any other garage can do it for me, only problem is that there aren;t any gargaes round my way that would probably even know what this stuff is and what to do with it.
Offline asif
« Reply #27 on: 31 March 2010, 16:49 »
Come on, a question like that aint gonna be any good in google, it'll come up with allsorts of crap.
Offline Rhyso
« Reply #28 on: 31 March 2010, 16:53 »
You won't find it cheaper than R-Tech mate.  Some garages who sell it want twice what R-Tech charge for the cleaning kit
Offline asif
« Reply #29 on: 31 March 2010, 16:56 »
Oh I must've misread what you were saying then, when you said "try finding someone who will do it cheaper I thought you was saying that was a dear price.
Cool then R-tech it is then, still not heard a word bad about them which is brilliant and very comforting to use them for any work. I'll probably use them for servicing aswell.
