Author Topic: Anniversary TDI few questions????  (Read 6839 times)
Offline spadey
« on: 30 March 2010, 21:05 »
Hi there
just bought my silver anniversary and its pretty awesome. Few questions.
The air bag light is on and the guy said it is because it has a nokia hands free kit fiited!!!!! Is it worth buying a resrt tool off flea bay to reset it???
The revers lights dont work and he has a part on order that attaches to the gearbox, firstly will it fail its mot on this as its due soon and is it a simple part to fit??
Im sure I will have other questions but thought I would give you guys something to start with...
Steve
Offline Rhyso
Re: Anniversary TDI few questions????
« Reply #1 on: 30 March 2010, 21:08 »
1) sounds like a load of rubbish
Code reader won't reset the light if you have a problem - most likely cause of the light are an airbag was disconnected whilst the the battery was still connected or a common problem is the wiring loom under the seat has an intermittent connection
No reverse lights is NOT an MOT failure
Offline spadey
« Reply #2 on: 30 March 2010, 21:11 »
Thanks for that mate, thats why I got him down £500 to be able to sort the problem..... What is the best way to get it fixed? vw specialist? The reverse lights from a little research is a small thing that just plugs in somewhere but doesnt effect that much.
Just would like to get the airbag light sorted.
Steve
Offline Rhyso
« Reply #3 on: 30 March 2010, 21:11 »
where abouts are you based?
Offline spadey
« Reply #4 on: 30 March 2010, 21:17 »
Based in Cumbria, any recommendations?
Steve
Offline Rhyso
« Reply #5 on: 30 March 2010, 21:20 »
Steve
Not that far North  :sad:
Might be a member local to you with VAGCOM who can help identify the problem though
Offline spadey
« Reply #6 on: 30 March 2010, 21:22 »
Cool what is the best way to find out? The car is quite awesome just want to get the little things sorted if poss ......
Steve
Offline topher
  • Administrator
  • fully functioning
« Reply #7 on: 30 March 2010, 21:24 »
They probably pulled the dash fuse when installing the hands free kit which can put the airbag light on when it loses comms with the module. Cheapo scanners only read engine faults so won't be able to access the airbag module to see what the issue is. If it's not a comms error then it's usually down to the plugs under the seats.
Cumbria is a bit far for me to travel just to look at airbag issues... but if you were after a mobile remap.. :wink:
Offline spadey
« Reply #8 on: 30 March 2010, 21:29 »
Seriously mate, I was thinking of a remap, not just for power but for mpg......... What price for a remap and how would a 90k tdi clutch etc handle it? I wouldnt be ragging it it really would be a economy thing. Hey and if you fix the air bag light all in then we may have a deal.
Let me know price and when you can come up??
Steve
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 30 March 2010, 21:42 »
It really depends on the life the clutch has had up till now. If it's had a hard life it may start to slip as soon as the remap is on the car. If it's been treated well you might get another 20 - 30k out of it. Either way it's best to budget for a new clutch in my honest opinion at that sort of mileage. No need for anything fancy just a genuine standard replacement from vw or tps (unless you plan to go further with the tuning, hybrid turbo etc.).
If you're not heavy with the right foot all the time then mpg increases are usually seen.. but that can be hindered by boost leaks, failing coolant temp sensors, maf sensors and clogged up EGR valves so that's the sort of stuff i check over before the remap. I can investigate the airbag light at the same time.
I'll drop you a pm about making a booking :afro:
