Author Topic: We got a bleeder!!!  (Read 2486 times)
Offline Mr_Orange
We got a bleeder!!!
« on: 30 March 2010, 18:21 »
Got home tonight to find I'm in what seems to be not such an exclusive club:
http://uk-mkivs.net/forums/p/155942/1029860.aspx
 :cry: :cry: :cry: :cry: :cry: :cry: :cry:
06A121132AP component price from VW now £11+vat
« Last Edit: 30 March 2010, 18:33 by Mr_Orange »
Build thread clicky
Offline richw911
Re: We got a bleeder!!!
« Reply #1 on: 30 March 2010, 18:39 »
 :cry: Dam it  :angry:
Cheap fix at least.
Offline Mr_Orange
« Reply #2 on: 30 March 2010, 18:47 »
Aye £11 for the part.
Got it all stripped out ready to whip the old one off, but what to do with my coolant?  I'll fall asleep to the sound of it drip-drip-dripping away!  What's the likelihood of me draining just enough from a hose at that point?  Surely the whole lot aint gunna come gushing out?
Build thread clicky
Offline Mr_Orange
« Reply #3 on: 30 March 2010, 19:18 »
Just tried to drain some out.  I got more up my sleeve than in container.  Will leave it 'til I got the new part and then get stuck in.
I think this may have been on the way out for a little while, just came a bit of a conclusion this afternoon.  There's always been a certain amount of guff on/around the top of the gearbox, I assumed it was oil vapour from previous split breather hoses or oil sprayed up from the diff seals which I already had replaced.
I've never removed the air box to have a good look around that bit, but can see more clearly now what's happened and where and on a positive note, I also saw how easy the TT selector change is!
Build thread clicky
Offline ian007miles
« Reply #4 on: 30 March 2010, 19:19 »
All rite mate y don't you put a bucket under the radiator and undo the tap like thing at the bottom of it and then once it's all drained and you put the car back together, u can reuse the coolant if it's clean and free of grit that way it don't cost as much. Thanx ian
« Last Edit: 30 March 2010, 19:20 by ian007miles »
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline Mr_Orange
« Reply #5 on: 30 March 2010, 19:24 »
Car is stuck out on the roadside so I'm not getting under it.  The tap you mention don't work (tried it last summer doing my thermostat), so it's a hose off job and I don't have the patience, inclination or motivation required to even look at the f##kin car again today.   :cry:
Build thread clicky
Offline T_J_G
« Reply #6 on: 30 March 2010, 23:01 »
Bugger would pop down and give a hand but proper busy :(
Offline Mr_Orange
« Reply #7 on: 31 March 2010, 18:55 »
Had another go at it tonight.
Couldn't release the SAI hose from the kombi valve, worried I would brake something if I carried on?
Managed to drain some more coolant as I got the radiator tap undone at last (it unscrews and then pulls out!!!).  Fluid looks like new still, so will be putting it back in.   :wink:
However with the temp sender out, I can still see coolant that will no doubt pi55 all over me/the car when I take the bracket off - anyone got any ideas to drain that further?
Build thread clicky
Offline michaelnabbi
« Reply #8 on: 31 March 2010, 19:45 »
jack the car up on the passenger side and all the remaining coolent will run to the driverside of the engine prosto no leakage hope this helps you stay dry
Offline T_J_G
« Reply #9 on: 31 March 2010, 20:33 »
I vote for just get wet!
