Author Topic: forge 007p  (Read 3871 times)
Offline pitchy
forge 007p
« on: 30 March 2010, 17:31 »
since i put my 007p on about a month ago iv felt like the boost was down slightly and was wondering if my spring is too weak?
ive since read an article all about the 007p and seen that you can shim the spring to adjust the strength , i was just wondering what size/increments are the spacers ? the valve dumps at the slightest little sniff of me backing off so i reckon its in need of a shim or two , il make a few up at work if i can find out the thickness . cheers
2002 gti aum mods-cai / n75j / 007p / stg1 remap / rs4 reps .
things done in the last few months - new temp sensor / new gearbox oil / anni matts / painted interior trim / debadged /
things to do - refurb wheels-satin black / coilovers / paint headlights internals black / fit fmic / 3" turbo back / stg2 remap
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Re: forge 007p
« Reply #1 on: 30 March 2010, 17:46 »
Have you had a remap? You should have got 3 springs with the DV, green, yellow and red.
Green is meant for standard cars, yellow for remap stage 1 (& maybe 2?) and red spring is for hardcore boost (about 28+ psi iirc)
I have yellow spring in mine and its fine, just remap no mods.
Offline pitchy
Re: forge 007p
« Reply #2 on: 30 March 2010, 17:55 »
yeah its had a re-map stg1 but awesome didnt suply any extra springs, i may have the lowest spec spring in ?
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Re: forge 007p
« Reply #3 on: 30 March 2010, 19:27 »
Open it up and see? Should be colour coded... If not then i think you would have to get some other springs to check how hard each one is against each other...
Offline pitchy
Re: forge 007p
« Reply #4 on: 30 March 2010, 20:07 »
the spring can be adjusted with spacers as i was saying before, its in the maintenence guide for 007p, just need to know the size of the spacers to try
Offline pitchy
Offline pitchy
Re: forge 007p
« Reply #6 on: 01 April 2010, 17:01 »
emailed awesome about my problem with my weak 007p and aparently forge has changed their spring manufacturer , in between this some valves went out with faulty springs , mine being one of them :undecided: but theyre sending me spacers to sort it  :smiley: so all good
Offline Stronz
  • Sold!
Re: forge 007p
« Reply #7 on: 01 April 2010, 20:26 »
Did they say how they identify the DV's affected?
Offline Rhyso
Re: forge 007p
« Reply #8 on: 01 April 2010, 20:31 »
Why didn't they just send you a new spring  :huh:
Offline pitchy
Re: forge 007p
« Reply #9 on: 01 April 2010, 20:38 »
thats what i was hoping he would say :undecided: either way the spacer will do the same thing i supose.
stronz- u can tell if it dumps really easy , i can cruise at 2000rpm and back off just a fraction of a mm and it dumps , since i put it on i also felt like power was down slightly
