Author Topic: Hi Jonny  (Read 1278 times)
Offline laurenceyon
Hi Jonny
« on: 30 March 2010, 17:03 »
What is the part number for a Fuel Accumalator on a MK2 J-92 16V Golf? I also need a new Hall Sensor as my valver is running like a bag of spanners and cuts out everytime I dip the clutch.
And how much are they?
Thanks in advance  :smiley:
Hi my name is Laurence, I'm very much like you. Only better.
Re: Hi Jonny
« Reply #2 on: 31 March 2010, 11:10 »
from gsf:
185VG0070 - FUEL PRESSURE ACCUMULATOR - 115.00
923VG0180 - HALL SENDER - 38.50
best to replace the internal oil seal while you have it apart, need 12x19x5 size. I got mine from simply bearings, the type with a lip:
http://simplybearings.co.uk/shop/
bit of a b!tch to get the roll pin out, but once you've got that out its plain sailing from there. Just make sure you note down the position of the drive tooth bit on the base in relation to the dizzy shaft :)
Offline Agreeable Slick
  • Unit
Re: Hi Jonny
« Reply #3 on: 31 March 2010, 18:48 »
IM?
