Author Topic: Alternator fuse melting!?  (Read 5601 times)
Offline smitty12
  • R32
« on: 29 March 2010, 23:24 »
Last week my car decided to melt the alternator fuse on top of the battery after a quick fix i replaced the fuse and it was fine,
Although its happened again tonight :sad:
Any idea's what could be the problem...?
Mk7 Golf GTI Clubsport S Tornado Red - on the way!
Mk4 Golf R32 Grey Anthracite Pearl Effect
Mk4 Golf GTI 2.slow Yellow Colour Concept
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Alternator fuse melting!?
« Reply #1 on: 30 March 2010, 00:05 »
replace the cable :wink:
Offline smitty12
  • R32
« Reply #2 on: 30 March 2010, 09:31 »
could it just be the cable?  :huh:
Offline mattkh
« Reply #3 on: 30 March 2010, 17:02 »
Hi
Which cable, the one going from the battery fusebox to the alternator ?
Offline richw911
Offline smitty12
  • R32
« Reply #5 on: 30 March 2010, 23:23 »
Yes :
http://www.golfgtiforum.co.uk/index.php?topic=111624.0
i've read this and it says to replace the fuse box on top of the battery? The box is £70 but the alternator wiring harnes is £40?
Which is it most likely to be?
I'd imagine the wire as its connected to fan and the air con unit? and the fuse box is just a lump of plastic really so cant see how that would make the alternator over charge?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 30 March 2010, 23:57 »
you only need to replace the box if it melts
The wire is breaking down which in turn is sucking all the power from the alternator which makes it heat up the wire. Just take the wire off that runs from your fuse box to the alternator and get a new one made up, shouldn't cost more than a tenner from an ICE shop. VW want around £30 for it  :shocked:
