Author Topic: Throttle Body Question.  (Read 1144 times)
Offline christomk3gti
« on: 29 March 2010, 14:28 »
Hi guys,
Was gunna take off the throttle body (8v GTI AGG) last night at work using the quides on this forum.... anyway i decided to read the Haynes Manual (wish i hadnt) and it says I need to drain 1/4 of the coolant before i remove the throttle body??? I decided not to do it in the end because of this...
Is this correct?
Anyone fancy giving me a exact quick guide of taking off the throttle body for a clean..??
Christo
Black 8v GTI............. Whats a Waffle Valve?
Offline axewielder
  • 95 dragon 8v
Re: Throttle Body Question.
« Reply #1 on: 29 March 2010, 16:04 »
no you dont, just when you take the coolant hoses off the tb dont let them hang right down as coolant will leak, when i did mine i lost about 5ml + the bypassed the tb altogether by running the coolant hose straight to the header tank
« Reply #2 on: 29 March 2010, 16:51 »
ok thanks for that mate,
I will be getting a throttle body gasket aswell and maybe afew spare gaskets for future cleans... Are these gaskets cheap?? Eurocarparts??
Offline Matty-MK3
  • Automatic boats FTW.
« Reply #3 on: 29 March 2010, 17:59 »
I did one today on an 8V Cab as it happens.
I took the pipe off the top of the coolant bottle and the flange instead of the throttle body itself. This was just to make it easier.
Then I blocked up the flange with another bit of pipe and a bolt and none comes out of the bottle.
There is a multiwire plug underneath, three pipes to remove, I replaced one clip with a jubilee clip. Then carb cleaner and some motton cloth and it was shiny and idled properly!
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
« Reply #4 on: 29 March 2010, 19:01 »
Cheers guys.
Will have a go one night this week then, need a gasket first tho.
 :wink:
