Author Topic: Rear brake pads  (Read 2101 times)
Offline Primus84
Rear brake pads
« on: 29 March 2010, 12:53 »
Hi, at some point over the Easter break I need to replace my rear pads (got an advisory on my recent MOT).
Just wondered, I've heard from a mate they're a bit awkward but as far as I understand it's just wheel off, unbolt the caliper, pull out the spent pads, use the special tool to push the piston in and put the new pads in then everything back together. Is there more to it than this or have I got it right?
If so I'll do it myself, but I'm just wondering where the cheapest place to get the pads will be (I'm not interested in anything fancy just standard OEM pads).
Thanks!
Offline FamilyDub
Re: Rear brake pads
« Reply #1 on: 29 March 2010, 13:40 »
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_2006/p/Car-Parts/Brakes/Brake-Friction/Brake-Pads
Pagid are OEM, I believe.
Nicked the link Hurdy posted last week!  :tongue:  :laugh:
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline Primus84
Re: Rear brake pads
« Reply #2 on: 29 March 2010, 17:59 »
Anyone able to comment on the complexity (or lack of) of replacing the rear pads?
Offline Hurdy
Re: Rear brake pads
« Reply #3 on: 29 March 2010, 20:36 »
It's an easy job. Just like you described :smiley:
15 min job per side once the wheel is off :cool:
I'm assuming the special tool you are referring to is the twist one?
Seat Leon Cupra Black 290 DSG
Offline Primus84
Re: Rear brake pads
« Reply #4 on: 29 March 2010, 21:12 »
Yeah, you turn it to push the piston backwards.
Offline Hurdy
Re: Rear brake pads
« Reply #5 on: 30 March 2010, 01:31 »
You shouldn't have any worries then :smiley:
