Author Topic: Jamex Coilovers ?  (Read 20761 times)
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
Re: Jamex Coilovers ?
« Reply #30 on: 04 May 2010, 17:58 »
No Wax oil is generally put on the underneath of a car to protect it. Copper grease is usually used to prevent threads sticking etc etc
good to know   :wink:
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
Offline godsANGER
« Reply #31 on: 05 May 2010, 19:47 »
Had some bad news the guy who was going to fit my Coilovers has died in a motorbike accident, R.I.P he was a sound guy.
I can get them done for £40 front and £40 Rear but i was only originally be paying £35 for them all, So Two questions :-
Is £80 a good price?
Also how had is it to fit the rear shockers, hight adjustment thingiy and the springs ? because i want to cut right down on labour costs i was thinking fitting the rear ones and having them set high then driving to the garage and then paying for the fronts fitted, lowed to the high i want.
Then lowering the rears once i have the new coilovers fitted on the front.
« Last Edit: 05 May 2010, 19:54 by godsANGER »
Offline lemonadeX
« Reply #32 on: 05 May 2010, 20:24 »
The back ones are pretty easy - much easier than the front. Obviously you'll need a jack, axle stands and socket wrench - worth checking but I think the top of the strut needs a 16mm socket and the bottom bolt needs an 18mm. You might be able to do it without, but a spring compressor comes in very handy to get the old spring out and put the new one in. The new one will have an adjuster on the bottom which, when you can screw in/out using the provided C-spanner to get it at the desired height - really easy to do yourself. I wound mine to the very bottom before fitting to set it at its lowest. Then jack the car up and turn clockwise with the C-spanner to raise it up if needed.
Any questions let me know. Fitting the Jamex was the first thing I had attempted relating to the suspension and the back ones really were pretty straightforward - just the front ones that are a b!tch to get out.
However a decent spring compressor will cost you £20+, and £80 doesn't sound a bad price to me for having the whole lot fitted. Like I say, if you want to adjust them afterwards all you will need is a jack, axle stands (to be safe) and the C-spanner which comes in the box with the coilovers.
Will
« Last Edit: 05 May 2010, 20:26 by lemonadeX »
Offline godsANGER
« Reply #33 on: 05 May 2010, 20:35 »
Will
Again Will your there with a answer  :smiley: , thank you.  :laugh:
think ill do the rear my self at my mates near the garage then drive down and get them to do my fronts and get the hole thing aligned.
Didn't think £80 was to bad but when it gose from £35 [mates rates] to £80 just a bit  :sad: lol but think ill  be happy with £40 fronts fitted.
also found this in the maintenance section
http://noahlh.com/car/coilover_howto/
should come in handy as well  :wink:
« Last Edit: 05 May 2010, 20:40 by godsANGER »
Offline mick ov mids
« Reply #34 on: 05 May 2010, 20:46 »
£20 a corner sounds a very good price mate as i was quoted £40 a corner obviously meaning id be paying £400+ for coilover's and fitting  :undecided:
[img width=500 height=200]http://i836.photobucket.com/albums
Offline godsANGER
« Reply #35 on: 05 May 2010, 22:08 »
So £80's good then.  :smiley:
Also dose anyone know if i well need wheel spaces for my TT competition alloys for when i fit them ?
Offline blackgtigolf
« Reply #36 on: 05 May 2010, 23:56 »
depends on where you live as jamex on ebay do a fitting service and includes 4 wheel lazer lining for £125, i paid £80 last last time for 4 wheel lazer lining only!
or stick with the £80 coz thats a good price
i shud get my jamex coilover tomorrow then its guna be a fun weekend fitting them with my new 18s
Offline godsANGER
« Reply #37 on: 06 May 2010, 08:28 »
Going to order myn tonight or tomorrow, depending on what time i get back from work, and hopefully order my adjustable drop links as well. Then all i need is the nuts and bolts from VW top mounts from TPS or VW, and copper grease for the threads.
not missed owt have i ?
Offline lemonadeX
« Reply #38 on: 06 May 2010, 10:42 »
I followed that tutorial as well - http://noahlh.com/car/coilover_howto/
Just make sure you have all the bits listed there to do the rears.
Will
Offline TinuxGTI
« Reply #39 on: 06 May 2010, 21:26 »
I got my jamex fitted today and was a pain in the arse, just make sure that if you have 18'' wheels get the right spacers, I ended up buy 4 packs as 2 were wrong. But still have to file down the others so they fit nicely. Other then that it's nice. Lowered 60mm. :)
