Author Topic: door locks doing my head in  (Read 3777 times)
Offline garfield
« on: 28 March 2010, 09:19 »
hi all after a long time away from vw ownership ive got my hands on a mk 3 estate diesel and she has a couple of issues 1=it dont lock !!! the key turns in the barrel but doesnt engage on either of the front doors and the drivers side wont even let me lock it by pushing it manually and 2= the rear electric windows dont work
any ideas of what i should look at first
cheers all
Trevor
wehay its topless
Offline VR6-Joe
Re: door locks doing my head in
« Reply #1 on: 28 March 2010, 10:09 »
The locking issue: The paddles between the barrel and the lock mechanism have snapped, you need to remove the door handles and replace the paddles. The reason the drivers door won't lock is so that you don't lock your keys in the car. If you close the door and climb over from the passenger side it should lock, although if you lock both front doors you won't be able to get back in the car?? So probably best to get them fixed first!!
The electric windows issue: Are you using the front double switch or the two individual switches on the rear doors? The double switch on the dash has a push button which 'locks' the rear windows so that children can't open them etc, so if they're 'locked' then you won't be able to open them using the two individual switches in the rear. If they don't work from the switch on the dash, they could have knackered motors/regulators, or it could be a broken wire between the door and car :smiley:
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline garfield
« Reply #2 on: 28 March 2010, 10:38 »
cheers mate the window prob isnt that lock button /the back buttons dont seem to work, when you use the front switch the rear left mechanism makes a noise but nothing happens and the other side does nothing at all
cheers for the lock info can i pick the paddles up from a scrappie or will they have to come from a main stealer?
wehay its topless
Offline VR6-Joe
« Reply #3 on: 28 March 2010, 10:46 »
If the passenger one makes a noise then I reckon the cables on the regulator have frayed or snapped. The drivers side one could be anything from a broken wire, to a knackered motor, or once again, broken cables. Best thing to do really is to pop the rear door cards off and investigate :)
I've found a lot of scrappies would rather sell the handles complete (meaning you'd have a different key for locks + ignition). I don't know if VW sell the repair kits but they sell them on ebay..
http://cgi.ebay.co.uk/VW-GOLF-MK3-FRT-DOOR-LOCK-REPAIR-KIT-1992-UPTO-07-1997_W0QQitemZ310159598611QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item4836f3e413
Offline garfield
« Reply #4 on: 29 March 2010, 11:29 »
ive managed to get the old handle off but cant seem to see anything broken so not sure what to get from the scrappie
any ideas people
wehay its topless
Offline garfield
« Reply #5 on: 29 March 2010, 12:09 »
just found the broken bit im off to the scrappie .will update later
wehay its topless
Offline garfield
« Reply #6 on: 29 March 2010, 19:51 »
locks done the bloke at the scrappie let me have just the paddle and whats better hi didnt charge me wehay
wehay its topless
Offline green gti
« Reply #7 on: 29 March 2010, 21:46 »
vw do a door barrell repair kit for all locks!not bad money.not very nice to fit ,need 3 hands and patience of a saint! but when done do work.motors for electric windows do play up when not used,try going down and hitting the motor at the same time,does work on most models.or check for power at the motor.
