Author Topic: VAG com  (Read 3925 times)
Offline tom-gardiner
VAG com
« on: 28 March 2010, 00:37 »
imtempted to get this...
http://www.vagcom.co.uk/
but how easy is it to use. just want to put like alarm bleep on and windows up with key fob ect. is this easy or a pain in th arse?
also what else will i need aswell as VAG com :)
thanks, Tom
« Last Edit: 28 March 2010, 00:42 by tom-gardiner »
The Clio didn't as it's naturally aspirated and French  :sick:  :laugh:
My Project Thread ;)
Offline Mr A
Re: VAG com
« Reply #1 on: 28 March 2010, 04:30 »
im thinking about getting the vagcom bits too..
you will also need the cable, available on ebay...
http://cgi.ebay.co.uk/VAG-COM-USB-DIAGNOSTIC-CABLE-409-1-OBD2-II-LEAD-VAG-COM_W0QQitemZ350333301841QQcmdZViewItemQQptZUK_Diagnostic_Tools_Equipment?hash=item51917df451#ht_7209wt_925
are these cables any good??
what can be done without registering the software, ive read that you are restricted to what you can do?
i would just like to read for fault codes and try and get the code for my gamma radio, if its possible..
- 1999 MkIV Golf TDi -
*  Repairs Needed = Faulty Passenger Door Module, VAGCOM set-up, Rear Wiper, Rust Treatment, Rear Wiper Motor, Battery or Glow Plugs, Stubby Aerial,
Offline Cacwn Tew
  • God I'm getting old........
Re: VAG com
« Reply #2 on: 28 March 2010, 14:04 »
Dont know about the radio code but Vag software 409.1 which is free off Ross-tech is very easy to use and follow with plenty of info within the web site and on the forum.
http://www.ross-tech.com/
and good fun knowing the stealers are not charging a fortune to clear bity faults at a stupid price!!!!!
Happy days
GTi to Transporters to GTi
Offline linz
  • vee-dub
Re: VAG com
« Reply #3 on: 27 May 2010, 15:49 »
i have the ross tech cable but no you can not do the window closer with this
you need a different vag cable
