Author Topic: vagcom faults need abit of help  (Read 1890 times)
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
« on: 27 March 2010, 18:49 »
scanned the car today and got so codes up can anyone shed some light on them please.
16525-oxygen(lamda)senor-response to slow
16523-oxygen(lamda)senor-heating circuit malfuction
17746-camshaft position senor-open or short to plus
16804-catalyst system-bank1
16885-speed senor
Offline richw911
Re: vagcom faults need abit of help
« Reply #1 on: 27 March 2010, 18:50 »
Lamda sensor or wiring
Offline (shakey)
« Reply #2 on: 27 March 2010, 18:55 »
hope it just the wiring,what about camshaft position rich and speed senor
Offline Devilz
  • Cruisin is not a crime
« Reply #3 on: 27 March 2010, 19:36 »
I just ran vagcom as well to see if there are any errors and here is the result
VAG-COM Version: Release  311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01     -------------------------------------------------------
   Controller: 06A 906 018 CG
   Component: 1.8L R4/5VT MOTR HS D02
   Coding: 04000
   Shop #: WSC 00028
1 Fault Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
            P0116 - 35-10 - - - Intermittent
Readiness: N/A
Address 46     -------------------------------------------------------
   Controller: 1J0 959 799 AH
   Component: 4U Zentral-SG Komf. 0001
   Coding: 04096
   Shop #: WSC 00028
3 Faults Found:
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
00943 - Heated Exterior Mirror: Driver Side (Z4)
            35-00 - -
01358 - Internal Central Locking Switch: Driver Side (E150)
            27-10 - Implausible Signal - Intermittent
End   -------------------------------------------------------
I am sickin tired of this coolant temp sensor error, keeps coming back  :undecided:
Offline richw911
« Reply #4 on: 28 March 2010, 00:16 »
The same  :undecided:
