Author Topic: wd40??  (Read 728 times)
Offline bobreece
wd40??
« on: 27 March 2010, 16:27 »
trying to get my hoses on i used some wd40 as lube spray aroung the hoses and onto the turbo connector now some wd40 went into the turbo not loads but a spray or 2 will this be ok or cause a problem?
Offline Purely VAG
Re: wd40??
« Reply #1 on: 27 March 2010, 16:30 »
Don't worry about it, It evaporates after a while anyway.
Half a can then yeah i'd flush it out first but couple of sprays.
If you've got some brake cleaner, it would be ideal to spray that where you put WD to clear it up anyhow.
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
