Author Topic: Fuel and additive question  (Read 2681 times)
Offline danny_p
Re: Fuel and additive question
« Reply #10 on: 26 March 2010, 23:10 »
8v's will run on pond water
all the VW's have gone bar 1.
Offline Neo Badness
  • Feet are for pedals
« Reply #11 on: 27 March 2010, 02:26 »
:grin:
But in reference to OP, I've tried both on a K-jet 16v and it seems to make little to no difference unless you have an ECU that will adapt to the octane. As stated newer t/c cars see the biggest differnce, sure there was a 5th gear about it. Otherwise you'd have to setup the engine on higher octane fuel and only run it on that...
Additives = snake oil as far as I can gather.
PS 16vs win :tongue: :wink:
Offline danny_p
« Reply #12 on: 27 March 2010, 09:28 »
16v's on 95 can do this
niked from niges thread on northloop, cause was slightly diffrent but effect is the same. just rare to get optimal photos, quite often ppl drive till the piston gives up completly and exits
« Last Edit: 27 March 2010, 09:31 by danny_p »
Offline johnson6672
« Reply #13 on: 27 March 2010, 09:36 »
Alot of subaru drivers carry octane boost around just incase they can't get hold of super unleaded, although as said most new cars will adapt to the fuel you put in.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline Khare
  • The bear that khares
« Reply #14 on: 27 March 2010, 14:57 »
if the car has a knock sensor it will adapt to the fuel used. If it's made to run on 99RON and you stick 95RON it will adapt but will loose power.
A car made for 95RON will run nicely on 99RON but without HUGE gains, just more smoothness and better top end if anything. Advantages of 99RON is that they usually have addictives in them to help clean the engine on the inside.
Offline Neo Badness
« Reply #15 on: 27 March 2010, 20:39 »
What? KR engines or ABF run on 95?
What causes that failure?
The fuel burning too early or not well enough?
Offline twistedblack69
  • Proud mk2 user and abuser
« Reply #16 on: 27 March 2010, 21:03 »
So if I started running my '91 digi on 98, would I gain a couple bhp back? Last time I had it rolling road'd, it was only putting out 102bhp. Also, would there be increased mpg?
Offline Sam
  • Sam I am
« Reply #17 on: 27 March 2010, 21:11 »
Mines full of tesco sh!te at the min and i havent seen over 20mpg since getting it back, it runs high 20s on v power
