Author Topic: mark-mk3gti - 8v GTI  (Read 31834 times)
Offline mark-mk3gti
Re: mark-mk3gti - 8v GTI
« Reply #20 on: 25 January 2011, 16:28 »
attempted to photograph full frontal showing both meshed panels but due to pants weather it doesnt look amazing, but here it is,  also shows wolsburg surrounds with pressed plates..
things to do
change splitter to vr one, or one of the others pictured in mk3 threads
suspension lowered (desperately, hoping to be done for pod in april)
both sides have below rub strip treated and resprayed
rear headrests fitted
would love opening rear windows, does anyone know if its possible? :)
new sill covers
air box smoothed inside and another feed attached down wing for a bit more air and noise
« Last Edit: 27 July 2011, 17:02 by mark-mk3gti »
Offline mark-mk3gti
« Reply #21 on: 02 February 2011, 16:33 »
now sprayed lower vents black,
btw dont know what that silver thing is in the middle but it isnt on the car, lol
Offline mark-mk3gti
« Reply #22 on: 11 February 2011, 21:07 »
As you may of read in mk3 section i was fed up with dodgy paint on front bumper textured bit, so after trying to high pressure wash it off and rubbing with thinners, resorted to painting it again in matt black.
So after 5hrs today and looks like this now, just need to finish the grill off, thought while I was there I may aswell do that aswell! :) and all being well i should have hella quads aswell for the front..
Also need to do arches and rear bumper now.. :) never ending..
After 3-4 coats of primer
After 3-4 coats of Matt black
After 3-4 coats of lacquer
Now drying
Back on the car
Close up, looks pretty good in most places, but are a few imperfections where couldn't get it smooth enuff, didn't wanna wreck the bobbles.....
Offline mark-mk3gti
« Reply #23 on: 14 March 2011, 20:56 »
Sorry fellers, bein a while, have being busy doing other things work and stuff.
plan to do the following as soon as finances allow
: Get both rear lower quarter panels de rusted and resprayed and a patch on
  passenger side sill.
: lower 40mm by some method, prob gonna use 40/35 spring kit as found that
  shocks on car are only 2-3years old so should be ok for a while, or try for a Jom
  40/35mm suspension kit.
  Gutted missed out yesterday at ultimate dubs, I hesitated buying for 99quid and
  when I went to get em they had none left! Epic fail! :(
: get camber adjusted, as it needs a tweak!
: fit a stainless pipe to replace centre box
: pick up a pass rear arch and spray as mine is scratched
: need to repair drivers seat, as bolster worn through, think I am getting the
  necessary parts from another forum member off a passenger seat so will rebuild
  seat.
: fit a vr front splitter
: considering having the roof doing in Matt black vinyl
: considering White pin striping, have the stripe but unsure as yet
« Last Edit: 27 July 2011, 16:53 by mark-mk3gti »
Offline mark-mk3gti
« Reply #24 on: 16 July 2011, 18:17 »
Wow, where have the last three months gone!
Not much going on, no money, :(
Fitted standard plates for a while, they in carbon fibre lettering, look good and are legal! :)
Had mot 3 days ago and passed straight away, with 2 advisory, which is slight corrosion on front to year brake line and rear brake line, so after holiday will have to be getting them sorted!
Other than that not much happening as said poor, :( :(
Wanna try n get springs on ready for santapod in sept, for the weekend, need it looking better for then!
Will try and do some free stuff so I can post up pics!
That's all folks,,,,,, for now
Offline mark-mk3gti
« Reply #25 on: 23 September 2011, 00:23 »
hi all,,
finally got round to taking on the top nuts, me and my mate chrisford_vw did at his pas garage so we had air tools  :evil:
First issue, couldnt get the compressor to work right, so couldnt use the knocker gun, :(  so we tried with a rather long (2ft bar) but just turned the top plate and shaft right away.
so I decided we need to try and hold the top plate, but not with much success untill chris found these
now we had somet to grip them plates with, lol
straight away the nut came undun, even the damaged one, and we were able to remove them with really little effort, so it appears that the nut had corroded to the top plate not the shaft as I had thought.
once we had the first one off, it came to trial fitting the new plates I picked up, all the early stuff, plate, bearing, nut, but it didnt look right, and we bounced it a bit and the plate moved, we both werent happy with this,  lol it just doesnt look right, but im told this is the way to get mk2 suspension on a mk3 with mk3 mounts, anyhow fortunately the kit came with mk2 mounts so we put them on instead...
im just not happy with the way the spring top sits, so abandoned the idea of using mk3 mounts..
so we finally done the first corner and had some good results with height! :)
before
after
( i know they are different sides, i forgot to take both pics of the same side, lol)
the rears went on easy enough, fortunately the bottom bolt's nut is held onto the leg with a funky clip, so just a matter of prizing the bolt out, which to be fair took some effort then had to put a bar in the leg and push it down to remove the leg, as chris will vouch quite hard work and the first time it caught him on the jaw :D :D  which i was apologetic about, i thought they would drop, not spring up, lol
the rear should come up a little cos its full of tools and old kit, so hopefully should be slightly nose down
but theres more
we were in a rush to get to pick his littleun' up and set off and straight away some nasty banging from the front right, we had a look and the top stop plate was higher than the other side, and the rubber peeled slightly, bugger top mount appears to be knackered, we had a good look and this appears to be what is the problem, chris rung round and noone had one in stock, and vw and tps wanted 60+vat and 50+vat respectively per side!  :shocked: :shocked: but didnt have any!  and we were running out of time so it was either fit orignal gear back which we didnt want to do, obviously, so he rung his uncle and thank god he had one on a shock setup he had in his back room, so we went back, nearly 5pm lol and changed to top mount, drove round the block and alls good.
But for peace of mind i want to get new mk2 top mounts, so does anyone know of any good ones that may not be original brand? im guessing gsf and ecp ones are gonna be crap?
I know you get what you pay for, but i dont drive it hard, and its mostly cruising round the ring road for work etc.
Had a look on fleabay and spotted these?  what you guys reckon?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150664309910&category=42609&_trksid=p5197.c0.m619#ht_623wt_905
"VW Mk2 Golf G60 German Febi-Bilstein Top Mounts - Pair"
are they a good make?
so here it is after a good 7hrs hard work by myself and chris
if you read this mate, thanks very much again!! and will be getting the beers in!!!
before
after
Offline mark-mk3gti
« Reply #26 on: 23 September 2011, 00:27 »
Cold air feed on properly now! :)
:) just need to smooth inside now...
