Cheers paddy - got my eye on em!
Yup, it will come out through the engine bay - saves removing the dash, just a tight bloody fit!!
On subject of leaves collecting in the scuttle, good to keep em clean and check your rubber drain tubes at each end of scuttle. If you forget and they block, you will quickly get the scuttle overflowing with water, which drains into your heater fan - poss buggering this up? - but filling your footwells with water - i talk from experience!
