Author Topic: Boost Hose  (Read 1489 times)
Offline jonesltd
  • MK7 R
Boost Hose
« on: 25 March 2010, 09:46 »
Having fitted the boost pipe myself (your probably thinkin well whats the big deal you did it yourself but its bloody good considering a girl did it all by myself!)
Anyway is there any way I can attach something else on it to ensure it is kept in place?
If you cant find it......Grind it
Offline Waffs1984
  • Spacers are for chumps...
Re: Boost Hose
« Reply #1 on: 25 March 2010, 09:52 »
Which boost pipe?
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
Offline Rhyso
Re: Boost Hose
« Reply #2 on: 25 March 2010, 09:55 »
Not really as you're stuck with the rubbish OEM clip system
Only way is to replace or cut the lugs off the pipe at the EGR end and then replace the EGR itself with a delete pipe and use a big clamp to hold it in place
Offline jonesltd
  • MK7 R
Re: Boost Hose
« Reply #3 on: 25 March 2010, 10:02 »
ah right ok....ermm maybe pass on that
Offline Rhyso
Re: Boost Hose
« Reply #4 on: 25 March 2010, 10:04 »
Offline jonesltd
  • MK7 R
Re: Boost Hose
« Reply #5 on: 25 March 2010, 10:12 »
thank you but I am feeling a little out of my deepth and looks kinda expensive? replacing the EGR valve etc?
Offline Rhyso
Re: Boost Hose
« Reply #6 on: 25 March 2010, 10:15 »
EGR delete pipe is approx £65
It's the aftermarket hose that's expensive (circa £130) or as i said you cut the metal piece off your existing hose so you can slide it onto the EGR delete pipe and then use a jubilee clip to clamp it in place  :smiley:
