Author Topic: Keyfob not working  (Read 1628 times)
Offline 1.6mk4GOLF16v
Keyfob not working
« on: 24 March 2010, 14:52 »
what do i do, the alarm keeping going off everytime i enter the car, possible battery replacement? have to lock/unlock manualy
do i need a rplacement key or......?
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline T_J_G
Re: Keyfob not working
« Reply #1 on: 24 March 2010, 15:30 »
Get the battery replaced and go from there?
« Reply #2 on: 24 March 2010, 15:35 »
how do i open the dam thing?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
« Reply #3 on: 24 March 2010, 15:35 »
n what battery do i use?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline Mikesps
« Reply #5 on: 24 March 2010, 16:04 »
I'd use the batterys from VW, they seem to last longer than any others i've used.
« Reply #6 on: 24 March 2010, 16:53 »
ok so i took the battery out n put it in again (just to test)
now when i press it the little red light flashes but nothing happens to the car
do i need to reset it somehow or have i totally mashed it up?
:cry:
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline Mr_Orange
« Reply #7 on: 24 March 2010, 17:08 »
May need re-synchronising with the car... no biggie.
I'd get a brand new battery fitted first, dig out your 2nd key (if you have one!) and look up the numerous key / remote re-coding posts on the forum.
If you aint got a spare key, may require a trip to VW?.... :undecided:
Build thread clicky
Offline richw911
« Reply #9 on: 24 March 2010, 18:52 »
http://www.golfgtiforum.co.uk/index.php?topic=111526.0
http://www.golfgtiforum.co.uk/index.php?topic=77197.0
thanks for that
this is what i managed to google up:
The chip is in the remote part of your key, not the blade.
To program the remote functions on a new key, get in your car with the car off and the driver side window rolled down.
insert the new key into the ignition
insert your vallet key in the driver side door lock (outside the car)
turn the vallet key towards lock and hold it there
while it is held towards lock, press the unlock button on your new remote for
2 seconds.
let go
press it again for 2 seconds
let go and you should hear an alarm honk or something like that.
This is from memory so it may not be right. I would recommend searching archives.
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
