Author Topic: fitted 15mm rear spacers now grinding noice  (Read 3045 times)
Offline Steve_PD
Re: fitted 15mm rear spacers now grinding noice
« Reply #10 on: 25 March 2010, 21:40 »
wouldnt be the wheel bearing :undecided: does it do it on both sides or just one?
Offline rench
« Reply #11 on: 25 March 2010, 21:42 »
both and both screws that hold disc still had snapped from the play.
Offline Purely VAG
« Reply #12 on: 25 March 2010, 21:47 »
When you fitted the spacers, Did you remove the centre hub bolt cap - They intervene with fitment of spacers = Remove them.
Also i still think your bolts are too long and not actually securing the wheel because theyre bottoming out.
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline topher
  • Administrator
  • fully functioning
« Reply #13 on: 25 March 2010, 21:49 »
how much longer are the new bolts than your original ones?
did you put the spacer on the hub or on the wheel first?
Offline rench
« Reply #14 on: 25 March 2010, 21:52 »
center hub bolt cap.. not that i know of and i put them of the hub fisrt then wheel on them, erm bolts seem to be 15mm longer so they should be fine.
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #15 on: 25 March 2010, 21:52 »
well tightend the wheel nuts up tight and when i jack it up the wheel moves side to side as you turn it like the bolts are loose?
that to me sounds as if your wheel is not fully bolting up and as jordy has said the bolts are bottoming out into the hub
**also you mentioned you had the discs and pads replaced you do it or a garage if it was a garage ask them why they fecked your screws holding the disc  :evil:**
2000 Mkiv GTi 1.8T AGU
  • "1.8T AGU"
« Reply #16 on: 25 March 2010, 21:54 »
so 43mm length bolts then?
Offline rench
« Reply #17 on: 25 March 2010, 21:56 »
ill measure them later and see if they are.
Offline Purely VAG
« Reply #18 on: 25 March 2010, 21:56 »
It intervened with mine- Made wheels untrue with spacers so i had to remove them
Offline rench
« Reply #19 on: 25 March 2010, 22:12 »
botls are 41mm and no didnt remove anything.
