Author Topic: That pesky Exhaust Rattle Again!!  (Read 3819 times)
Offline Len
« on: 12 November 2004, 10:02 »
Had the heatshield taken off the CAT last night.
Still got the rattle/resonance! >:( >:( >:(
Where are there any other heatshields that maybe causing this?
I know there is one behind the inlet manifold. Is that the only one?
Could it be a slightly lose exhaust fitting?
Dont think its blowing, sure its not!
So any suggetions please!
www.sas.org.uk
www.the-ace.org.uk
Offline Overseer
Re: That pesky Exhaust Rattle Again!!
« Reply #1 on: 12 November 2004, 10:40 »
the rattle on mine was that thin shiny stuff that was above the pipe and seemed to run quite a distance downt he car..
not sure what bit that is?
i hit it with a hammer to keep it back in place and its seemed to stop it mostly..
is that the same as the CAT one you mentioned?
Offline Len
« Reply #2 on: 12 November 2004, 11:23 »
No the CAT one is underneath the CAT itself. Thats the one i had taken off!
So there's one between the manifold and the body then. Must be a bugga to get at!
www.sas.org.uk
www.the-ace.org.uk
Offline jv
  • Administrator
« Reply #3 on: 12 November 2004, 11:37 »
I had a Cordoba with the same mk3 16v engine for a while and the heat shield on that used to buzz a treat. That was the manifold one. Mechanic welded it in place a couple of times but said it was a nightmare and if you really were fed up with it, you may as well just get rid of it!
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Overseer
« Reply #4 on: 12 November 2004, 11:46 »
* wonders if we're talking about the same thing *
the bit i'm talking about runs right up the middle of the car above the exhaust.. i think its that shiny aluminium (cant be welded?) stuff you see around pipes in industrial places.. ?
Offline jv
  • Administrator
« Reply #5 on: 12 November 2004, 11:48 »
um, probably not then, i'll get my coat and be off now  :-[  ;D
Buy site stuff!
Offline hardo22
« Reply #6 on: 12 November 2004, 12:01 »
dont know if this will help,...on my mk3 there was a rattle/ buzzing caused by a missing rubber grommet on the heat shield above the back box........... it cost pennies to fix.......
mrwotto
« Reply #7 on: 12 November 2004, 12:04 »
My exhaust keeps rattling due the misses noit slowing down enough over speed bumps lol
Offline Len
« Reply #8 on: 12 November 2004, 12:05 »
Even thin ally can be welded by a good welder with the right kit!
Yes jv i know which one ya mean. Have tried to bend that one and tighten up the nuts.
The problem is i cant recreate it at a standstill. It only happens when driving i.e. under load.
So its bloody impossible to find where its vibrating!
Thanks Overseer i'll get it up on a ramp somewhere and have a good look!
www.sas.org.uk
www.the-ace.org.uk
Offline Overseer
« Reply #9 on: 12 November 2004, 12:13 »
i dunno if mine still does it, or that i got used to it..
rear passengers claim they can hear something..
i'm waiting for it to drop off so i can get SS run up throughout :)
