Author Topic: Quick horn question!  (Read 2253 times)
Offline cняis
« on: 22 March 2010, 21:56 »
Right guys one of my MOT failures was lack of horn  :shocked:
seeing as the current steering wheel boss has no horn button, this could be why  :grin:
i've bought a new boss kit with horn button, and was wondering... is there only one feed to the horn button? i.e. through the tab on the stalks to the back of the boss? obviously i have no original wheel to check.
if theres more than one feed, then im missing a wire somewhere!
Offline cняis
Re: Quick horn question!
« Reply #1 on: 22 March 2010, 21:59 »
forgot to mention i have an aftermarket wheel hence the use of a boss kit
Offline drapergti
« Reply #2 on: 22 March 2010, 22:50 »
There should be two spade connectors, to complete the circuit.
Offline cняis
« Reply #3 on: 22 March 2010, 23:08 »
so lets say if i was to remove an OE wheel, i would find two connectors coming from the steering column somewhere? in addition to the metal tab on the stalks?
if so, then the wiring has gone missing somewhere!  :shocked:
Offline drapergti
« Reply #4 on: 22 March 2010, 23:14 »
On my 1990, I have two wires with spade connectors that fix on two plates, when the two plates touch it gets completes. The wires come through the steering column on mine.
Offline cняis
« Reply #5 on: 22 March 2010, 23:37 »
erm ok...
looking at this pic the only way the horn push button connects is via the tab on the stalks, i.e. theres no seperate wiring from the column into the wheel:
i appreciate there are two connectors inside the wheel itself
Offline drapergti
« Reply #6 on: 22 March 2010, 23:39 »
Yours is a pre 90 spec I think, may be someone else can help.
Offline cняis
« Reply #7 on: 22 March 2010, 23:43 »
thats a pic from my old small bumper project but i hope (really hope) that the vr6 conversion i have, which is post 90, is meant to be the same... otherwise i have wiring thats gone walkabouts... and i really dont want to be tracking those wires down, its like spaghetti junction behind the dash at the moment  :cry:
i havent got my new boss kit yet and its getting closer to MOT retest time!
« Reply #8 on: 23 March 2010, 13:28 »
some horn push only have the 1 spoade, and earth thru a metal contact on the side to the body of the wheel boss. mine is like this :)
Offline Sam
  • Sam I am
« Reply #9 on: 23 March 2010, 14:54 »
Yer thats why i need to replace my entire stalk soon cos of that wangy setup
