Author Topic: Crankshaft pully?  (Read 1476 times)
Offline Toby
  • Car - less
Crankshaft pully?
« on: 22 March 2010, 19:05 »
I have a photo of the "crankshaft pully" which has a bit out of it, which could cause the timing to be out? which is the reason for the engine not to start?7
its a 1989 8v gti
Any help much appreciated
Currently down under
Offline Sam
  • Sam I am
Re: Crankshaft pully?
« Reply #1 on: 22 March 2010, 19:06 »
Eh? Photo? :laugh:
Offline Toby
  • Car - less
« Reply #2 on: 22 March 2010, 19:07 »
well its printed, i could take a pic of the pic and upload if thats any help.. no scanner :sick:
Offline Toby
  • Car - less
« Reply #3 on: 22 March 2010, 19:12 »
top pic is a close up the angles bi should be square?
Offline danny_p
« Reply #4 on: 22 March 2010, 21:04 »
that can bugger everything right up.    not a dusel by any chance is it
all the VW's have gone bar 1.
Offline Toby
  • Car - less
« Reply #5 on: 22 March 2010, 21:13 »
dusel? diesil?
no petrol mate lol
Offline danny_p
« Reply #6 on: 23 March 2010, 01:11 »
that is a top habbit of diesel's ( i just call them dusels atm for some reason )   bit unusual on petrols unless there g60's
the cause of the fail was the big 19mm bolt not been tight enough. sadly officaly the cranck is now unservicable AKA fked
altho it can be botched if you get a new key and clean the keyway right out till its shiney push the key right up to the leading edge ( good one ) and pack the gap on the other side with some really good epoxy. let it go proper hard and then sligthly roughen the shaft and the inside of the lower cam belt pully cover both with plenty of strong loctite then torque it right up with a new bolt.
Offline Toby
  • Car - less
« Reply #7 on: 23 March 2010, 07:34 »
OR just get a new one?
Offline danny_p
« Reply #8 on: 23 March 2010, 17:56 »
if the crank is ok  you can,  if the cranck is'nt you has to botch or replace cranck
Offline Toby
  • Car - less
« Reply #9 on: 23 March 2010, 18:00 »
yeh i spoke to a few mates micanics and they said its sh!t and f**ked lol  :sick: and will be a right job to do the new pully set up timing again and get it running... if that is really the real problem..?
