Author Topic: Thoughts on this boost gauge/anybody running one? - *WIRING QUESTION PAGE 2*  (Read 2950 times)
Offline Waffs1984
  • Spacers are for chumps...
Cheers guys! I knew about the blue wire on the dimmer switch from a Vortex thread i read lastnight - this also means that the guage should dim with the rest of the lights when you use the dimmer switch right?  :cool:
Hopefully i'll just tap into those screw terminals then. Need to pop by a Halfords on the way home to get some more vacuum line as the length that was supplied with the gauge was not long enough  :rolleyes:
For the record i have fed the vacuum line via the wing (as i do believe Rhyso has done) using the rather large grommet in the door shut just below the hinge.
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
