Author Topic: Thoughts on this boost gauge/anybody running one? - *WIRING QUESTION PAGE 2*  (Read 2950 times)
Offline Purely VAG
Re: Thoughts on this boost gauge/anybody running one?
« Reply #10 on: 23 March 2010, 01:23 »
Drivers side vent guage mount, Where did you get that from so cheap?? they're expensive
Only ones ive seen are SWG and theyre £100
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline Waffs1984
  • Spacers are for chumps...
« Reply #11 on: 23 March 2010, 09:21 »
I think i have confused some people with my rubbish explanation lol!
No i'm getting a standard 52mm gauge pod, like in the lower right of this picture (from google images)...
http://www.stackltd.com/images/aux_g_mounts_top_box.png
...and then i'm mounting it on top of the small circular vent (~1.5" round thing) is on top of the dash.
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
Offline Waffs1984
Wiring Question!
I have three wires,
+12v ignition
ground
dash lights
Are all three of these available to tap into from the headlight/dimmer switch by the drivers door?
Cheers,
Matt.
Offline DarkGti
look at the fuse box in the drivers side there will be some wires there.
what colour wires or on the gauge?
Offline johnson6672
Just been looking at boost gauges on ebay, found one that looks nice and seems to match the dials http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270550607145&ssPageName=STRK:MEWAX:IT
But what i want to know has anyone done a triple gauge pod thats not pillar mount, but more like the Focus ST (i will wash my mouth out later) style one.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
ignition - removes the smoked screen when you turn the car on (you can tap into the feed for the headunit for this)
earth - self explanatory
dash lights - again, self explanatory (tap into grey/blue wire on the back of the dimmer switch)
dub268
Look up under the dashboard at the fuse panel. You will see several threaded connectors here. The stud marked 75x supplies SWITCHED 12v ie when igntion is off no power and ignition on power  :grin:. The studs marked 30 (either one) will supply CONSTANT 12v. You can pick up a ground on the stud marked GND in the picture, that secures the fuse box to the bracket. Like wazzzer says grey/blue on the back of dimmer switch for dash lights
Offline asif
tagged as this is a good topic I may need info from in future.
MK7 GT Bluemotion Tech TDi 150
Offline asif
Just a quick question, where does the guage get the info from about boost pressure? What does that connect to?
dub268
If its like mine or jordys it has a boost sensor which takes a feed from the vac line and then sends info to gauge but on the needle gauges the vac goes direct to the back of gauge.
