Author Topic: Oil Standards  (Read 2535 times)
Offline golfmk4owner
Oil Standards
« on: 22 March 2010, 11:04 »
Hi guys, i was just wondering, does engine oil have to confirm to the exact and only the exact specification in the handbook, or can it use the stated spec and anything newer?
For example, my GT 130 needs VW505.01, but does that mean the newer vw507 will work as well, because its newer (i think lol)?
Just curious what exactly these specification numbers are based on and what they represent.
thanks!
2005 GT TDI 140 - Standard as F@k
Offline Rhyso
Re: Oil Standards
« Reply #1 on: 22 March 2010, 11:06 »
newer stuff will cover the older engines too :afro:
I normally get mine from VW itself as i found that using other oils I'd have to top up between services (even though it was to VW spec)
using VW Quantum Platinum or whatever its called these days and it doesn't require topping up even though its remapped  :cool:
Re: Oil Standards
« Reply #2 on: 22 March 2010, 11:22 »
Ah right... so basically, always get the newest oil? Kind of renders older oils useless then?
Is there a benefit to newer spec oils (if i used 507, for example, instead of 505.01)
And yes Rhyso i noticed that Quantum oil at the VDub dealers and believe it or not its cheaper than what ive been using!
I paid £39.99 for 4.5L of Castrol 505.01, and found 5L of 505.01 in VW for £29.99!
Offline Rhyso
Re: Oil Standards
« Reply #3 on: 22 March 2010, 11:44 »
I would use the newest stuff simply because oils get better through R&D :afro:
See dealers aren't always stealers  :wink:
Offline asif
Re: Oil Standards
« Reply #4 on: 22 March 2010, 15:27 »
Quantum PD oil FTW
MK7 GT Bluemotion Tech TDi 150
