Author Topic: tickety sound.  (Read 2794 times)
Offline mwep201081
Re: tickety sound.
« Reply #10 on: 22 March 2010, 17:41 »
before you go unbolting things I'd go over the car with a fine-toothed comb and look for anything that is loose. Brackets, heat-shields etc...
Offline Sam
  • Sam I am
Re: tickety sound.
« Reply #11 on: 22 March 2010, 17:47 »
+1 i can be a little enthusiastic
Offline bmm
  • Be patient... I'm an idiot
Re: tickety sound.
« Reply #12 on: 22 March 2010, 18:17 »
For what it's worth, my 87 digifant sounded like a tin full of nails on super unleaded/optimax and much better on the regular cheap stuff.  Seems to go against Reasty's post, but I'm guessing my engine couldn't advance/retard the timing to make the most of the slower burning fuel or something.  I'm not too technical, so it's probably wrong!
Offline edpryce
Re: tickety sound.
« Reply #13 on: 23 March 2010, 00:59 »
I think its definitely engine related, it seems pretty consistent with the accelerator and i generally know my other rattles ha.
that puts my mind at ease a little!
I  filled up with cheap stuff again today to try to flush the other stuff out, see if there is any progress.
Offline OakeyDoak16v
Re: tickety sound.
« Reply #14 on: 23 March 2010, 01:11 »
I'd take it to a garage mate rather than try to describe an engine noise problem on here as you will never get a straight answer without us hearing  the noise ourselves. Can you record the sound and post up on here? May help a bit. :smiley:
« Last Edit: 23 March 2010, 04:09 by OakeyDoak16v »
Offline edpryce
Re: tickety sound.
« Reply #15 on: 23 March 2010, 01:57 »
I'd take it to a garage mate rather than try to describe an engine noise problem on hear as you will never get a straight answer without us hearing the noise ourselves. Can you record the sound and post up on hear? May help a bit. :smiley:
i'll have a go, can imagine the wind would drown it out.
I think i am going through the expensive phase of mk2 ownership.
Offline Sam
  • Sam I am
Re: tickety sound.
« Reply #16 on: 23 March 2010, 08:33 »
I think i am going through into the expensive phase of world of mk2 ownership.
Offline weazgti
Re: tickety sound.
« Reply #17 on: 23 March 2010, 20:51 »
In my experience if its timing too far advanced it makes it hard to start when warm aswell as pinking.
Offline mk2_abf
Re: tickety sound.
« Reply #18 on: 23 March 2010, 21:16 »
Ive had a 1.6 driver thats had the same problem a put super unleaded in by accident sounded like a bag of spanners for a couple of days put unleaded in after that it sorted itself out thought this might help before you go to any garages
Offline edpryce
Re: tickety sound.
« Reply #19 on: 24 March 2010, 02:57 »
yeah cheers, i am going to try and flush it out, see if there is any progress before looking like a tool at a garage.
