Author Topic: Help Gear box oil leak?  (Read 728 times)
Offline ian007miles
« on: 21 March 2010, 13:41 »
Just a quick question . If my gear box was leaking oil would it leak all the time or just when you move (changing gear while drive) . I no it sounds a bit drange but it just I've changed the side cover on the gear box because it had a hole in it and was leakin , and I just drove to my mother inlaws house and I looked underneath and the is a line of oil on the floor right under the gear box, so I looked around but could not see any drips, so I put some card down to see if leaks. Thanx ian
« Last Edit: 21 March 2010, 15:51 by ian007miles »
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
