Golf mk3
hardmonkeys
Golf mk3 2lit 98 keeps stopping..got lots of fuel, and sparks..please help! (2nd
Topic: Golf mk3 2lit 98 keeps stopping..got lots of fuel, and sparks..please help! (2nd (Read 1849 times)
bmw156
GTI forum regular
Re: Golf mk3 2lit 98 keeps stopping..got lots of fuel, and sparks..please help! (2nd
Reply #10 on:
22 March 2010, 12:23 »
Quote from: rubjonny on 21 March 2010, 10:10
sounds crank sensory to me, have you had the fault codes checked
just thinking the same.
its beside the oil filter i think, check for split wires
javalin
Reply #11 on:
22 March 2010, 13:07 »
its behind the oil filter - use a torch to check the wiring. mine was shot -
http://javalins.wordpress.com/2010/03/13/dodgy-sensor-wiring
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
green gti
Reply #12 on:
29 March 2010, 21:29 »
hi mate,could be crank sensor,would start with cheching dizzy cap and rotor arm,cheap so buy decent new set.pattern coils do play up under load.just the rotor arm will give this fault! and no fault code will be displayed,hope this helps
Golf mk3
hardmonkeys
