Author Topic: headlight wooooos  (Read 1998 times)
Offline leeroy20vt
  • h reg mk2 gti
headlight wooooos
« on: 19 March 2010, 20:43 »
if u got any ideas would be great
when i put main beam on there fine when u put full beam on the drivers side goes to dipped and the spot light dont work on the same side
but both work fine on passenger side
also got no dash lights any ideas ???
cheers lee
Offline peaky83
Re: headlight wooooos
« Reply #1 on: 19 March 2010, 21:03 »
Left and right full beam have separate fuses and if the full beam fuse is blown the symptoms u describe would happen... Check the fuses 1st and let us know...
Hope this helps,
Dan
Offline leeroy20vt
  • h reg mk2 gti
« Reply #2 on: 19 March 2010, 21:07 »
Hope this helps,
Dan
cheers m8 will have a look
Offline weazgti
« Reply #3 on: 20 March 2010, 10:04 »
On mine some cock put the main beam spotlight plug in my sidelight and vice verca because the grille had been swapped for nasty one and they are the same plugs.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #4 on: 20 March 2010, 10:15 »
ok will look into that to but surly the side lights wouldnt work both sides
also checked fuses this morning all good
Offline leeroy20vt
  • h reg mk2 gti
« Reply #5 on: 21 March 2010, 23:24 »
any one??
« Reply #6 on: 22 March 2010, 11:37 »
time to get a multimeter! check for 12v between the high beam pin on the headlight plug and the battery -ve, and then check for continuity to ground between the brown wire on the headlight plug and the battery -ve.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #7 on: 22 March 2010, 12:31 »
cheers fella will check that today if i get a chance  :smiley:
Offline Gloves88
« Reply #8 on: 22 March 2010, 16:56 »
I had the same issue on mine but I just put in an uprated loom as I wanted the headlights to be better anyway and this got round the issue...(couldt find out what the problem was)
I know thats not really the answer to your question but it is one of the best mods I've done on the car, really improving the headlights so I just thought I'd mention it.
Fire a post up if you do work out what was wrong tho....be interesting to know.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #9 on: 22 March 2010, 17:54 »
yup a made a uprated loom in my old golf the lights were so bright also put 80/100wat bulbs in that made a hell of a differenc eto i will have a look tom and see if i can work this out doin my head in lol
