Author Topic: MK4 Rear Caliper Problem  (Read 977 times)
Offline darylb
« on: 19 March 2010, 14:02 »
after the tyre man noticing that my rear drivers side brake pad had worn all the way down but passenger hadnt, i changed the pad and now when i get home i smell brakes and there was a bit of smoke coming from my rear drivers side caliper.
why could this be? any ideas?
Offline Rhyso
Re: MK4 Rear Caliper Problem
« Reply #1 on: 19 March 2010, 14:04 »
sounds like the piston caliper is stuck on therefore literally driving with the brakes on
you can remove and clean them up.  worse case scenario is you'll need a new caliper  :sad:
Offline darylb
« Reply #2 on: 19 March 2010, 14:26 »
ooo sounds like fun not what i really wanted cheers for the info
Offline The Dave
« Reply #3 on: 22 March 2010, 11:08 »
Dead common problem, always the drivers side too. Finally gonna swap mine next month and new discs and pads at the back :)
