Author Topic: VAGCOM logs  (Read 1936 times)
Offline T_J_G
VAGCOM logs
« on: 19 March 2010, 12:58 »
Anyone got a link of how to do a log on the MAF for an AUM?
Offline Rhyso
Re: VAGCOM logs
« Reply #1 on: 19 March 2010, 13:00 »
Go to
Engine, Measurements, Log Block 2 or 3 i think
Offline T_J_G
Re: VAGCOM logs
« Reply #2 on: 19 March 2010, 13:05 »
Then start it and do a full throttle run in 3rd or pootle about then start it ad do a run?
Offline Steve_PD
Re: VAGCOM logs
« Reply #3 on: 19 March 2010, 13:18 »
003
yes start it and the 3rd or 4th gear from as low rpm as possible and floor it repeat a few times
Offline T_J_G
Re: VAGCOM logs
« Reply #4 on: 19 March 2010, 13:22 »
So it'll save all the data from my drive but then I need to select which bits to analyse?
Offline Steve_PD
Re: VAGCOM logs
« Reply #5 on: 19 March 2010, 13:27 »
when you open the log up in excel your see 'throttle position' 'rpm' MAF specified' 'MAF actual'
compare what the specified is and the actual
Offline T_J_G
Re: VAGCOM logs
« Reply #6 on: 19 March 2010, 15:31 »
I did 003 And 115
for MAF I got air mass in, throtle angle and ignition. Not the ones you suggest Steve
Offline Rhyso
Re: VAGCOM logs
« Reply #7 on: 19 March 2010, 15:35 »
I did 003 And 115
weird
is yours a full version or just the shareware version Tim?
Offline T_J_G
Re: VAGCOM logs
« Reply #8 on: 19 March 2010, 15:36 »
Full version 311. The boost logs are interesting.
Offline Rhyso
Re: VAGCOM logs
« Reply #9 on: 19 March 2010, 15:37 »
email me a copy :afro:
