Author Topic: wheel offset!  (Read 1866 times)
Offline darren1.8t
  • I HATE FRENCH CARS
wheel offset!
« on: 19 March 2010, 12:43 »
hi guys i have been offered a set ov 18inc subura alloys the are 5x100 7.5j would thease fit my mk4 gti or will i need anuthing else? thanks guys  :undecided:
Offline darren1.8t
Re: wheel offset!
« Reply #1 on: 19 March 2010, 12:44 »
they have a 48 offset ?????
Offline Rhyso
Re: wheel offset!
« Reply #2 on: 19 March 2010, 12:48 »
need spacers
Offline darren1.8t
Re: wheel offset!
« Reply #3 on: 19 March 2010, 12:52 »
cheers any idea what size?   :sad:
Offline Rhyso
Re: wheel offset!
« Reply #4 on: 19 March 2010, 12:54 »
nope
also the I'm sure on the other threads lately there is something about the centre bore not being right so not sure if they would fit even with spacers
Offline northeast_gti-t
  • "1.8T AGU"
Re: wheel offset!
« Reply #5 on: 19 March 2010, 12:57 »
you may need p.c.d adaptors  :undecided: these will be in pre-set thickness i believe
2000 Mkiv GTi 1.8T AGU
Offline Steve_PD
Re: wheel offset!
« Reply #6 on: 19 March 2010, 13:21 »
isnt the centre bore a different size on subaru wheels :undecided:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: wheel offset!
« Reply #7 on: 19 March 2010, 13:32 »
15mm spacers will take you down to ET33. Not sure on the centre bore, you'd need to measure it...
Re: wheel offset!
« Reply #8 on: 19 March 2010, 13:36 »
Yes plus the bolt holes are smaller as they run studs not bolts.
Offline Grand Master Patch
Re: wheel offset!
« Reply #9 on: 19 March 2010, 15:46 »
Subaru's have a 56.1 centre bore and mk4 golf have 57.1 so you will need a spigot ring at the very least.
