Author Topic: Brake problem  (Read 3382 times)
Offline peaky83
Brake problem
« on: 19 March 2010, 00:44 »
My brake pedal goes down 2/3 of the way before it does anything, could this be air in the brake lines/ checked the fluid and that looked a little low  too, could that be a cause too?  :shocked:
Offline molegti
Re: Brake problem
« Reply #1 on: 19 March 2010, 07:19 »
Id suspect a leak. Fluid out and air in. Go round and check all the connections, hoses to calipers etc.
Offline peaky83
Re: Brake problem
« Reply #2 on: 19 March 2010, 11:17 »
UPDATE: Brakes slow me slightly very slightly when i press the pedal and until i get 2/3rds the way down thats all they do, no extra force. When I get the pedal down far enough they work ok...
Topped up fluid and its made no difference... HELLLLP !  :cry:
Offline molegti
Re: Brake problem
« Reply #3 on: 19 March 2010, 12:15 »
There'll be air in the system so they'll need to be bled. You'll need to fix whatever caused the air to get in, in the first place.
Offline sprout99
Re: Brake problem
« Reply #4 on: 19 March 2010, 12:21 »
master cylinder seals might be shot
is yours 8V (239mm Brakes?) My 8v was terrible
the 16V stops on a six pence
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline peaky83
Re: Brake problem
« Reply #5 on: 19 March 2010, 12:33 »
Yes its an 8V... whats the likely cause of this?
Offline Ben Lessani
Re: Brake problem
« Reply #6 on: 19 March 2010, 12:46 »
As above.
Spongey is water/air in the lines.
Unresponsive or lots of travel is usually master cylinder.
Offline peaky83
Re: Brake problem
« Reply #7 on: 19 March 2010, 14:50 »
right... GSF have 2 Master Cylinders available, the GSF budget one and one manufactured by a German company...
GSF - circa £35
German - circa £55
Which one would you recommend I go for?
Offline peaky83
Re: Brake problem
« Reply #8 on: 20 March 2010, 09:59 »
Update: it appears that the brake pedal has a lot less play if I pump the brakes before I use them so I v much doubt it's a leak, does this narrow the possibilities down guys? Please help!
Offline weazgti
Re: Brake problem
« Reply #9 on: 20 March 2010, 10:09 »
They is full of air. Thats why pumping them first makes them work. When you bleed them your going to be pumping it the same to get the air out.
