Author Topic: what power?  (Read 3677 times)
Offline tom-gardiner
what power?
« on: 18 March 2010, 22:33 »
i have a AGU 1.8t, what sort of power figures would i see from a r-tech remap, miltek catback 4motion style exhaust, forge DV and PiperX filter? also would i need a stage 1 or 2 remap with these mods?
also is there anything else that is needed/advisable to get at the same time as all this?
thanks for any help guys
The Clio didn't as it's naturally aspirated and French  :sick:  :laugh:
My Project Thread ;)
Offline Purely VAG
Re: what power?
« Reply #1 on: 18 March 2010, 22:36 »
Been covered numerous time before mate.
AGU standard remap wont see more than 190bhp.
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline master_oogwai
Re: what power?
« Reply #2 on: 18 March 2010, 22:40 »
You have everything required for stage 1 already.
The extra oomph should keep you amused for a while.
Re: what power?
« Reply #3 on: 18 March 2010, 22:49 »
okey thanks guys
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: what power?
« Reply #4 on: 19 March 2010, 10:13 »
I was pushing out 198bhp but had the addition of a 3 inch downpipe and de-cat, this helps the turbo spool up quicker and let the exhaust gases exit quicker, less stress on the turbo
Offline navmk4gti
Re: what power?
« Reply #5 on: 19 March 2010, 11:57 »
how much did the downpipe cost you mate?? as im looking get one on my AGU.. also what sort power gains get just downpipe?? currently sitting at 190 bhp with r tech remap.. want bit more power  :evil:
i already have a custom cat back exhaust system  :wink:
Offline northeast_gti-t
  • "1.8T AGU"
Re: what power?
« Reply #6 on: 19 March 2010, 12:26 »
K03-s it then  :tongue: i know yours is an AGU but for a rough/approx guide for my aum i got the miltek 3" downpipe & cat and it was approx £325 iirc
2000 Mkiv GTi 1.8T AGU
Offline MickeyC
  • Mk4 GTI 1.8T
Re: what power?
« Reply #7 on: 19 March 2010, 17:05 »
check the mods in my sig, i got 195bhp with all them
ive had a 3" downpipe and hi flow sports cat fitted now tho by Pipewerx so it might of changed a tad
Offline Hulmie
Re: what power?
« Reply #8 on: 19 March 2010, 17:34 »
not sure what gains you will get from just a downpipe and de-cat, but it is a worthwhile mod as it removes the restriction caused by the standard downpipe and cat, which like i mentioned will help your turbo spool up quicker.
With you already at the 190bhp mark then next step would be to look at changing to a K03s turbo unit and fit a larger downpipe at the same time. personally i wouldnt just change the downpipe if your going to stick with your current turbo.
Also another mod would be to upgrade the standard TIP for a larger better flowing Forge one, but if your going to upgrade the turbo to a k03s then i'd get an AUM TIP instead of a AGU one.
Maybe give R-Tech a call to talk through your power requirements, i recon they will give similar advice
Offline jeynesey
  • Non VW but still VAG
Re: what power?
« Reply #9 on: 19 March 2010, 18:42 »
Have that exact setup and mine is 188  :smiley:
