Golf mk2
is there
Topic: is there (Read 1967 times)
theclash
Here all the time
is there
18 March 2010, 21:41 »
is there a seperate bulb for the mfa/clock or is it built in coz mines lost its light
weazgti
Re: is there
18 March 2010, 21:45 »
2 bulbs top of the clocks and 1 for mfa.
theclash
Here all the time
Re: is there
18 March 2010, 21:48 »
so the mfa has a seperate bulb is it hard to get at ,do you have to take the clocks out or can you get your hand up the back
jamie_pyrite
Re: is there
18 March 2010, 21:52 »
I wouldn't say you have to take them out, but you have to undo the clocks and tilt them forwards. The amount of time/effort/frustration you'd put into trying to change it with the clocks still in wouldn't be worth it.
After doing it once, I could have the clocks out and back in in about half an hour now. And I'm quite slow
My Photography
weazgti
Re: is there
18 March 2010, 21:55 »
Have to take clocks out and there will be a bulb behind mfa. Clocks are quite easy to get out as long as you can get your hand in the left hand side to remove speedo cable and vac hose once its all loose and pulled forwards.
theclash
Here all the time
Re: is there
18 March 2010, 21:57 »
ok thanks guys job for weekend me thinks ...can you get standard bulbs from gsf or is there uprated ones
jamie_pyrite
Re: is there
Reply #6 on:
18 March 2010, 22:12 »
I paid something like 62p each for mine from our local motor factor
My Photography
theclash
Here all the time
Re: is there
Reply #7 on:
18 March 2010, 22:24 »
thanks jamie will have to get it sorted weekend little things like this niggle me lol
weazgti
Re: is there
Reply #8 on:
18 March 2010, 22:25 »
similar bulb holders in halfords which just about fit aswell
theclash
Here all the time
Re: is there
Reply #9 on:
18 March 2010, 22:34 »
weaz, jamie, thanks for both your help gonna see if i can get my fat fingers behind the clocks....cheers guys
Golf mk2
is there
