The garage
PAS on mk3 golf gti
Topic: PAS on mk3 golf gti (Read 1513 times)
stuyhird
Here all the time
PAS on mk3 golf gti
18 March 2010, 13:27 »
Tought i would give the pas a fluid change as it starting to sound like my belly when hungry, when i checked the fluid i was suprized to see that it was green, is this normal? where can i get it? what grade is it?
Thanks for your help!
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: PAS on mk3 golf gti
18 March 2010, 15:19 »
MK2s use ATF which is red, MK3s use a mineral fluid which is green. can use the red stuff in it if you like though, but need to make sure all the old fluids is drained, cant imagine the 2 types would play nice together
stuyhird
Here all the time
18 March 2010, 23:39 »
The green stuff is like piss water in it now, iv never seen what new fluid like!
ATF is quite thick from what i remember, should the green stuff be thicker?
rubjonny
10k hero
19 March 2010, 10:09 »
not sure how thick the green stuff is new, never used it! I know that some mk2s dont like the green stuff as its a bit thinner, so it can leak out of all the old seals.
Wayne
Sir Postalot
21 March 2010, 00:05 »
If a system has been running on ATF, do not use mineral fluid as it will rot the seals.
rsmithone
GTI forum regular
23 April 2010, 20:53 »
ok im new to the golf world i got a 8v mk3 gti and when im at low speeds my steering makes a noise like above to checked the fluid its red and its full should i change mine thanks in advance
http://s922.photobucket.com/albums/ad70/rsmithone/1st%20golf/?action=view¤t=DSCF0056.jpg
The garage
PAS on mk3 golf gti
