Author Topic: CV joints or something more sinister???  (Read 4059 times)
Offline peaky83
Re: CV joints or something more sinister???
« Reply #10 on: 18 March 2010, 14:58 »
hMMM, £15 WHERE FROM?
Sounds like a better idea to me...
Dan
Offline Mew
« Reply #11 on: 18 March 2010, 15:06 »
GSF and VWspares when i got mine. Just had a look though and they're more like £25 a side now, so maybe not the best route.......
Offline Brads MK2 GTI
« Reply #12 on: 18 March 2010, 15:38 »
Lol I know this is off topic but it reminds me of when I had a knocking noise coming from the front left when going around a corner ages ago. Spent ages wracking my brain checking CV, wheel bearing, suspension, anything that it could be. You know what it was? Turns out the bolt that holds the battery in had just come away with rust and the battery was slinging itself against my pas resevoir! Lol :)
Offline peaky83
« Reply #13 on: 18 March 2010, 15:40 »
now theres an excellent point... ill check that!
Offline james_16v
  • 1986 Golf GTI 16v
« Reply #14 on: 18 March 2010, 16:03 »
Cant see it being the wishbones, I replaced them with new last summer.
Plus the noise goes if I push the clutch.....
Any other suggestions?
Offline Horney
« Reply #15 on: 18 March 2010, 16:05 »
Release bearing in the box?
nick
Offline peaky83
« Reply #16 on: 18 March 2010, 16:06 »
Wet Gremlins?
Offline james_16v
  • 1986 Golf GTI 16v
« Reply #17 on: 18 March 2010, 17:18 »
HELP!!!
Things have just got a whole lot worse!
Pulled out of the works car park and ive lost all drive. Just hear a horrible grinding noise when with the clutch up.
Recovery man on his way but im stuck for work now as this is my daily.
What you reckon, gearbox??
Offline peaky83
« Reply #18 on: 18 March 2010, 17:31 »
Errrm, does it grind all the time or when in gear or with the clutch down?
Offline james_16v
  • 1986 Golf GTI 16v
« Reply #19 on: 18 March 2010, 17:41 »
I now grinds when in gear with the clutch up. its fine in neutral.
Just got it up quickly on some stands and the O/S outer CV joint is making a terrible crunching noise when I spin the wheel.
In fact I can actually feel loose ball bearings wobbleing about inside the boot!!
Would this cause me to lose drive totally even if just the one side is gone?
